This instructable has been removed by the author.
49
comments
Add Comment
Great Ible.
As a note, you can also regain electricity with an AC motor, even easier because no polarity swap, but storing power needs it separated first when using batteries or the like, say using a full bridge rectifier. However, the fish tank-style pump does not have the ability to turn air pressure into power.
It would probably work for actually moving the fluid as well, but I advise against this since brake fluid would quickly corrode the rubber and plastic parts inside of the pump, leading to a quick break down.
Also, since fluids are much more viscous than air and these pumps are designed to work at relatively low resistance and high speed, it would also burn out the motor pretty fast. So even pumping water (which would probably not hurt a good quality pump with strong seals) would be a bad idea.
is this right?my old VW had a vacuum storage system i still can not wrap my mind around storing vacuum.
It would take a prohibitively long time for this little pump to remove the volume of air for a bagging operation.
A larger pump like a refrigerator compressor will produce at least 27 inches of mercury and if that is used to evacuate a larger tank like an old propane cylinder first, your bagging or vacuum forming operation will work much better. There are plans available for this type of system on-line here at Instructables.
I've seen a larger hermetic compressor take out a large transformer when it was mistakenly started up while in a vaccuum.
It can be done, but just be aware of what you're doing to the motor inside.
Feel free to post some of your ideas for low vacuum uses.
I also use it for vacuum sealing electronic components.
thanx bud for the tutorial!
About the second pic here the small O ring is close to the rubber hing, is this the way it should look when your putting it back in?
By the way thanks for the compliment coming from the most requested machine on the net...
I hope that this helps.
