3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quick and Cheap CD/DVD/ pick a format Disc
Step 6Final Step!
Final Step!
Now its time for the clever bit. If you look at what we have so far, you will see that the last two fold flap around quite abit, and the CD can still slide out if the paper is thrown around.
Unfold the last two folds and refold them in the reverse order, so that the short of the two is onto of the longer. This is for looks only :-D
If you look in the picture you can see the channel which the two side folds created.
What we are going to do is slide the longer of the two flaps inside this channel on the smaller flap.
If you look at the second picture, you may understand abit better, the flap on the left is the shorter one, the longer flap slides inside this channel.
Once you have just got it in, you should have somehting like the Third picture.
Now gentlly push the paper flat, you might need to feed more of the longer flap in, it should end up like the fith picture.
And there you have it! Throw it around, see how well it stays shut, and yet it can be opened easily, and reclosed.
Write what is on the CD onto the paper, and there you go! no excuse for scratched CD's again.
Total cost? £0 ( Yes I do live in England WOOO!)
Most people will have a piece of paper lying around, if not, a ream of 500 sheets only costs £1-3, depending on where yoou get one.
Hope this has helped some people out there, :-D
3 comments
May 14, 2011. 5:22 AMubassmusic says:
Thanks for this great intuative design! I finally have something to enclose my EP's in! Thanks again!
Apr 14, 2009. 7:32 AMarirang777 says:
Very neat and simple. That's the way I like it. Now, if I just could have something (device, alarm, tactic, etc) to prevent people from holding discs from the main surface... Keep the good work Cp!
Jan 29, 2007. 5:24 PMmr bkilled says:
so simple yet guenies!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:CpHarding
