The method chosen to use to remove the labels was with a Dremel and a grinding disc attachment. It may be possible to paint over the keys giving a smoother look, but this is messier and the keyboard will be out of action while drying..
There are two steps in this instructable:
1. sanding/grinding the lettering from the keys.
2. fine sanding/polishing the keyboard to make it more presentable
Remove these ads by
Signing UpStep 1Grinding the lettering from the keys.
With the Dremel, grind all the desired lettering. In this step we are not concerned about the looks, but only that all the lettering is removed. However, don't grind more than needed as noticeable indents will be created.
having said that, paint works.
index - f
middle - d
ring - s
pinky - a
and for your right hand homerow is
index - j
middle - k
ring - l
pinky - ;
your thumbs rest on the space bar, and the idea is that your fingers remain on the homerow, each finger reaches out to the button it needs to press and then returns to its homerow key. is very difficult to learn, but extremely efficient once you've got it. best way to learn touchtyping.
my friends like to take the keys from several keyboards if they need more than one of a key, and then arrange them on a keyboard to say 'you smell' or similar.
