Quick and Dirty Wire Repairs
5,980
9
5
Posted
Introduction: Quick and Dirty Wire Repairs
Panic! The GFI outlet on my patio failed... The apartment complex will fix it for free in a few days but in the meantime I have my air pump plugged into an outlet inside my home and going through the sliding door space to my hydroponic garden: https://www.instructables.com/id/EQBFMQANUAERV7BV0D/ .
By freak (and by freak I mean screw up), I closed the door too hard and it severed/shorted the wiring on my pump. The breaker tripped but the cord was damaged. I used this opportunity to extend the cable and add a switch (so I wouldn't have to buy an extension cable when I relocate my pump closer to the garden).
This is my quick and dirty -- but effective - wiring repair... Saved me $12 (pump=$15) - well $22 if you count the extension cable :P
Step 1: Getting Started
Grab your tools and supplies.
A wire repair cord costs $3... while this little extension cord costs $1.25. So, I also got SP rotary switch for $1.50....
Go ahead and cut the bad wiring off - then cut the female portion of the extension cord off.
Step 2: Strip and Solder
Strip a section of wiring... If whatever you're repairing has a ribbed side and a smooth side - be sure to match each side of the wire to its counterpart. This is how polarity is handled in the ac electrician world :P
Glob on a bit of solder. If you have heat shrink (and I do not), don't forget to throw some on first. Otherwise, solder away - I know messy, but this is a hack - not something to be nice.
Step 3: Enter the Dirty
I was caught off guard... No electrical tape... no Duct Tape!!!
Solution, extra liquid gasket material. This is a fast setting stuff that dries pretty hard. Goop on and let it cure....
As for the switch, follow the directions on the box ;)
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    5 Comments
    Well done :P Easy, but well documented. And nice use of improvisational techniques.. But improvising is only good for so long, you should really get some duct tape :P Good Job! :P
    hehe, yeah I will - next time I get to the surplus store :D I should have mentioned that you should not cut the wires straight across... If you stagger each wire so that the solder joints are not next to each other -- you run less of a risk of shorting....
    Nice tip.
    It also allows you to add a wire tie between your joints for strain relief prior to insulating. (Not there there should ever be a lot of tensile load on your wires, but with extension cords and stuff, there often is some, and this offers a bit of extra durability)
    (+)==============(solder)=====||=========================
    (-) =========================||======(solder)=============
    You also may want to be careful with duct tape, some brands have conductive backing, but I like the liquid gasket idea, how hard does that stuff cure? can you cut/peel it off again if you need to?
    This particular material cures hard... really too hard for something like this. A better alternative would be black RTV which is softer and has that nice silicone rigidity :P
