Introduction: Quick and Easy Battery in 5 Minutes
Ever wanted to make a battery but didn't have the time or the parts? Well here you go. You can literally make this in 5 minutes with only 4 parts. It is sealed and doesn't require chemicals... what more could you want!
Step 1: Parts and Tools
Not much is needed for this instructable, but you will need:
A film canister (or similar container)
Aluminium Foil
Tissue paper or kitchen roll
Carbon rod (Pencil led or battery rod)
Electrolyte (Salty water or other salt in water)
Some wire
Tape
As for tools,
Scissors
Multimeter if you want to check it.
Step 2: Making the Cathode
The cathode is the negative terminal of the battery. For us, it is made of aluminium foil.
Start by cutting a strip of foil just slightly shorter than the film canister, but long enough to make a full ring inside with plenty of overlap.
Tape a wire to the foil so that it won't be facing inwards, but is against the side of the canister.
Try to curl the foil so that it will easily fit into the canister. Pulling it gently over a sharp edge does this nicely.
Insert it into the canister and leave it for now.
Step 3: Making the Anode and Electrolyte Medium
The positive 'side' of our battery will consist of a carbon rod surrounded by electrolyte. The carbon rod is the hardest part to get right, as it needs to have large surface area and low resistance. I used the carbon rod from an old 'C' cell battery. Although I haven't tried it, a artist pencil led may also work.
The anode needs to be surrounded by electrolyte, which we achieve by saturating tissue paper with salty water. I use bicarbonate of soda in water, but any salt in water will do.
Start by taking two sheets of kitchen roll or other tissue paper and folding them into a narrow band slightly shorter than the film cannister. You may need to trim the height with a pair of scissors.
Now place the carbon rod along with a stripped wire end on one end of the paper. Roll the tissue paper as tightly and as neatly as you can.
On to the next step!
Step 4: Filling the Battery
Now we have to fill the battery. Start off mixing up some electrolyte. Keep adding salt to warm water until no more will dissolve. Keep stiring it and it will dissolve more.
Next we insert the tissue roll into the canister carefully, making sure the foil is straight around it and not creased.
Push it all in tightly, as the lid has to shut and seal the electrolyte in.
Now to fill the canister. Pour the electrolyte in slowly as it has to be absorbed into the tissue. when it begins to overflow, drain off the excess and wipe it down.
Step 5: Seal the Cannister
Now we just have to feed the two wires out the lid. Puncture two holes it the lid with the scissors and feed the wires through.
Pull the wires right through and clip the lid onto the canister fully.
Now all that is left is to test it!
Step 6: Test the Battery
The final step is to test it out. We need a multimeter to test the battery accurately, but if you want to check it works without a multimeter, just put the two wires on your tongue. If you feel a slight tingle that tastes metallic it works!
If you want to be precise, measure the voltage and current with your multimeter.
My battery produces between 0.8 and 1.1 volts at around 2-5mA. Using a joule thief you could run an LED from this. A larger surface area and stronger electrolyte concentration would improve the battery, but that is up to you to try...
Enjoy!
sdkajlsfdafsdfsadfsda made it!
17 Comments
this is rechargeable
and you also need to use charcoal as it is more porous and will speed up the reaction
first your battery will eventually loose power as the aluminium oxidises.you could speed up the rate by adding hydrogen peroxide or any other oxidiser like kno3.and also connecting a number of them in parallel to get more amps or in serier for voltage
well seeing as an LED uses a small amount of power i would say for a fairly long time
how long will it work?
Can I use a copper rod instead of a carbon rod?
Very nice, Coggz. This is well documented, easy to understand, and cool! I think I'll use this for a science experiment with my daughter.
cool, you can make a mini boat that runs purely on ocean water.
Well, not exactly- the energy comes from the aluminium oxidising to form aluminium oxide. The salt water is just a part of the battery that doesn't contribute energy, because the energy you are releasing is actually the energy that was used by the electrolysis plant to make the aluminium in the first place. Coggz, if you have the relevant electrical theory and the equipment to test it could you find out the internal resistance of this battery? I'm interested to see how much current it could supply, and of course how long it will run for.
But you need the salt water/ionic solution. I know the anode would corrode about 1/2g per hour(i guess), but the boat gets powered by the ocean/saltwater.
