If you've seen my past instructables -- you know I'm a big fan of Time Lapse. However, using a miniDV digital video camera makes things quite expensive and the quality isn't quite as high as it would be with a digital camera. For those with nicer cameras with remote triggers - this really isn't too important for you. But for the rest of us with $75 floor model digital cameras, please - step into my office :)
I wanted to do some time lapse of Robot doing the robot -- the response I got was:
I do not do "the robot" I am robot.
Unfortunate
Remove these ads by
Signing UpStep 1Parts and Tools
Suitable Screw Driver(s) to partially disassemble your camera
Soldering Iron
Solder
You'll probably want a multimeter or continuity tester
Parts
Donor Camera
Timing Circuit*
Thin Wire (connectors optional)
12 Volt Power Supply
*For simplicity and to make reproduction easier for everyone else - I used a timer kit. While it's more expensive, it gets the job done and is a fairly decent package as far as adjust ability is concerned. If you want to build you're own - all you really need is an adjustable astable 555 circuit.
I bought my kit from an Orlando based surplus store - but the kit is widely available online. Searching Google for "MK111" yields a bunch of results for the very same kit I used.
or do i have to replace the relay to a lower voltage one
if so how long does the battery last
and how is the timing affected
My next project requires a long duration time-lapse. One or two frames per day over several months in a lava tube cave to study cave slime. Your Instructable is just the ticket to get me going, as my previous stuff relied on a laptop computer for intervelometer.
Thanks!
I felt the same way you do about opening up my camera, which is why I built an intervalometer (time lapse control) out of spare parts without damaging my camera, check it out! It's a bit involved but gets the job done.
Alternatively, the only other detailed documented project I've found anywhere on the web was also right here on instructables.
I hope this helps you out, good luck!
Simply open the first image, set your preferences such as compression (it saves as AVI, but uncompressed AVI's are big so choose xvid, divx, or like I do a lossless codec if you want to edit the film later) and maybe framerate
Then Save As and specify output avi filename.
I use it to handle upto 5000 images at once, but it can cope with a lot more (see http://narrowboat.blip.tv or http://narrowbo.at).
I may try this with an old 2MP camera I have.
http://www.giantscreamingrobotmonkeys.com/monkeyjam/index.html
Stop motion and time lapse are time consuming just figuring out all the programs, cameras, and then editing programs to upload them to video hosting sites.
Here is a Stopmo site that has a current listing of most of the freeware that is available for both Time Lapse and Stop Motion. Most of the programs are frame grabbers...
Stop Motion Works
You may need a batch processing program like xnview to get your frames into a compatible format that VirtualDub can use.
Both of these programs are free and are good.
Here my little solution for a similar problem: steady shots with a Sony camecorder. We need a:
- Sony Camcorder or similar
- HP Ipaq with IR Port
- Nevo Remote Control Program (included with Ipaq)
- Some automatic script program for pressing the buttons....i do it with Mortscript (http://www.sto-helit.de)
Next I leave the ipaq with the script running pointing to the camcorder and voila......i can take large videos or picture.... or do what you want...
Thank to your works for inspiration, sambort
