The current popular solution to the problem is recycling. However, recycling requires additional energy to process the material into something usable, not to mention the fact that the process itself can have harmful side effects. So a better solution, if you can't avoid the disposable containers altogether, is to reuse them. This requires no added infrastructure costs and concerns. In fact, if you are reusing junk, you are helping to make the initial energy that went into the production of that material last longer and go farther. It's not just about saving money, but more importantly, integrating your lifestyle with what is available for the least amount of cost, be it environmental or financial.
That said, here are 10 simple ideas on how to reuse plastic bottles around the homestead.
Keep updated on our ideas for this project: VelaCreations.com
Step 1: Mosquito/Insect Trap
Invert the cone and place it inside the straight part of the bottle.
Glue the two pieces together, using a glue or silicon.
Add 1 tsp yeast and 1/2 cup sugar to some luke warm water, and pour the mixture into the bottle.
Mosquitoes are attracted to the carbon dioxide that you exhale. The yeast feeds off the sugar and emits the same gas, so the mosquito enters the bottle, thinking she will find food there. She cannot then get out.
You can use the same bottle design for a fly trap, but fill it with a putrid smelling liquid. For wasps, use a sugar mixture. For fish, put under water, and add a bit of cheese or bread.
Step 2: Scoop
You now have a scoop. We use one for the cover material for the composting toilet, and one for chicken feed.
Step 3: Handy Holders
Step 4: Coldframe/Cloche
Cut the cone part off and invert the remaining part of the bottle over your seedling. Push the bottle into the soil, so that it does not blow away. In the middle of warm springs days, it is a good idea to raise the bottle a bit and allow air and heat to escape.
Step 5: Cookie/Biscuit Cutter
Step 6: Butter Churn
Separate the cream from your cow's or goat's milk and allow it to ripen a little. If you allow the cream to ripen a little, the butter will be more flavorful and easier to churn. Do not let it ripen too much or the butter will be sour.
Get the cream to about 60 degrees F.
Pour it inside the wide-mouthed bottle and screw the lid on tightly.
Roll the bottle back and forth on the floor for about 20 minutes, or until the cream separates into buttermilk and clumps of butter. This is a great chore for the kids to do!
Drain off the buttermilk (great for baking or milkshakes or animal feed).
Take the clumps of butter and beat them with a spoon until its all joined together.
Add salt � tsp per pound of butter (unsalted butter spoils faster).
Wrap butter in wax paper and put it in the fridge.
Step 7: Building Brick
Alternatively, leave the bottles empty, or full of air. This will give the wall a better insulation value.
Leave a bottle exposed, and insert a solar garden light in the other end. Instant wall lighting.
Step 8: LED Lightbulb
With a box cutter, cut the thread off the mouth of the bottle, so that it is smooth.
Take an old incandescent light bulb and smash the bulb. Clean any glass off the screw-in part.
Cut a circle out of a piece of thin card (diameter should fit inside the plastic cone).
Pierce the card with however many holes needed to make the bulb you want. We made 12 VDC bulbs, because our lights run off DC. We made one bulb with 6 white LEDs (which is not very bright, but works for a lamp) and one with a mixture of several white and yellow LEDs. However many lights you want and whatever voltage you need, you will have to make the voltage regulator match.
You'll need a 12VDC voltage regulator, 6 white LED's and a resistor.
Solder your LEDs together, positive to negative. Solder the resistor to the negative end. Solder the ends of this array to the respective leads of the voltage regulator. On the input side for the voltage regulator, solder the positive to the tip of the light bulb base. The negative goes to the side of the screw in part of the light bulb. Glue the plastic bottle to the base.
Step 9: Electric Fence Insulator
Using one half cut a Z groove on the open end. Directly opposite of the bottle, but still on the open end, cut another Z groove, and make sure to make it a mirror image of the first.
Now, on the closed in, make a slit or large hole for your post to run through both sides of the bottle. Near the slit, make two small holes, either side of the post slit. Use this end to wire to the post, and run the electric fence through the Z groove.
Step 10: Ice Pack or Feezer Thermal Mass
Step 11: Additional Ideas
Chicken Waterer - this is similar to the hummingbird feeder: Humming Bird Feeder The difference is that you make it much bigger and juts fill it with water, no sugar.
Low-flush Toilet - Since we have a compost toilet, we can't do this one. But for those of you with flushing toilets, this would be great. Just fill a bottle with water and put it in the top tank, out of the way of any moving parts. It will help your toilet use less water.
Bird house - cut a 2 inch hole in a 2 liter bottle, paint it, and hang from a tree. It is a good idea to insert a small wooden dowel for a perch.
Visit Our Store »
Go Pro Today »
they guide by carbon dioxide, that's how they find us humans ,even in the darkness, they keep track of increasing amounts of carbon dioxide.
I especially loved the "brick" idea.
What a great way to recycle!!
I am a city girl and would like to try my hand at this...but the Ripen Milk threw me for a loop. (natural born blone) lol.
stay classy planet Earth
Michel
Portugal
