3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quick and easy self-watering garden planters
Quick and easy self watering garden planters. Cheap, reuseable, recycleable. All you need are: milk jug(s) (1 or 2 quart), scissors, planting foam (used for live flower arrangements), and potting soil.
Step 1Clean a 1 Quart or 1/2 Gal milk jug, cut it in half. Be sure you're below the handle.
Clean a 1 Quart or 1/2 Gal milk jug, cut it in half. Be sure you\
52 comments
1-40 of 52next »
Jun 27, 2011. 11:30 PMpravs2k says:
The overflow works beautifully.And if you use the method where you decoupage the whole[ the two parts together } you have to have the hole - [ a little below the level of the inverted bottle top so that it does not touch the water.]To refill, place the bottle in a bowl of water until water starts flowing out of the little hole.This way you don't have to pull out [can't !!!] and check - if the container feels light just place it in water. Also ,decoupaging prevents light getting in - apart from of course camouflaging the bottle and making it look like a real store bought container.
Have pics but don't know how to send it- not very computer savvy !!!! HELP
Mar 1, 2012. 11:30 AMpravs2k says:
The pictures at last!!
The zebra striped ones are two litre bottles cut down to size.
The other two are of one of the decoupaged ones I made .
The zebra fabric one is made of tetra pack juice carton.
Apr 22, 2012. 11:15 AMpravs2k says:
Thank you for the comment.Glad you like them
The tetra pack one was made by sticking two packs together and decoupaging it with fabric- can do it with paper too,but it has to be waterproofed with mod podge.
Pictures of hanging two litre bottles were sent to 'soda bottle garden' instructable.This one is extremely easy.The bottles one on top of the other were decoupaged with paper napkins and waterproofed.
Thank you Aperkins and Botronics for great ideas.
Jun 30, 2011. 9:29 AMpravs2k says:
Thank you .Have sent a picture and instructions to Instructables via your easy upload page. Don't know if it went through. If it hasn't ,will try again.Have to learn how to transfer the pic. from my desk top to email to you!!!!
Mar 26, 2012. 3:36 PMygmoore says:
Wonderful idea! I needed to modify it slightly, I had trouble getting the plug of floral foam to stay in so I opted to use a coffee filter under the soil. Then the weight of the soil made top funnel section fall into the base so I hooked the two pieces together on two sides using a small hole and bread ties. I'm sure this is clear as mud!! I then put a strip of cotton t-shirt tied to the top of tie and dropping under the coffee filter into the water reservoir as a wick.
Mar 4, 2012. 8:03 PMgkaneto says:
Hello, everybody!
I just wrote an instructable about self-watering (mainly for indoor plants, but will work for some outdoor setups): really self-regulating, and no powering needs.
It is here: http://www.instructables.com/id/Self-regulating-watering-system
Hope someone find it useful.
Best wishes,
Gustavo.
Jul 9, 2009. 2:56 PMlinda4444 says:
How do you add water? Dump it right on the dirt, or did you put a hole in the handle, to add water to the bottom part?
Nov 20, 2011. 7:17 AMsallyab says:
Sorry. I'm obviously an idiot, but where is the plant - top or bottom? Do you put the water in the bottom and it travels up or put it in the top and it travels down? Is a 'planter' a UK 'plant pot'? I'm looking for something to use on a houseplant that's already potted - best yet is plastic bottle with a length of string poked into a tiny hole in its bottom, but yours might take longer to release its water...and so be better for me (if I could just understand your idea!)
Mar 28, 2009. 2:01 PMbusywoman65 says:
Does the bottom work as a water reservoir and how do you put it in? You do dampen the dirt some when you plant the seeds don't you? I am totally new. I know the questions sound weird but I'm trying to understand.
Apr 25, 2010. 8:39 AMhi187 says:
have you ever poked holes at about the line you think excess water is an issue? i was just reading another instructable that had an "overflow hole" that might come in handy in these jugs.
Thanks for the idea! I have been using jugs as a way to save wasted cold water when turning on the shower, but I have so many of them that I didn't know what to do. This will be a great way to use them.
Sep 30, 2009. 8:57 AMhithisishal says:
Any reason why you specified smaller jugs? Would gallon jugs not work?
Oct 2, 2009. 9:32 AMhithisishal says:
I set one up yesterday. I'm not sure if something is inherently not straight, because of the shape of the jugs, or if I just didn't cut straight, but my inside is a ocuple of inches lower on one side. I'll probably trip the outside down, because now most of my (fairly limited) daylight is getting diffused by the jug. And I'm growing algea already - I deff. need to cover the sides with something. But I think so far it is self-watering successfully. Either that or it just didn't dry up yet.
Jul 21, 2009. 8:01 PMguy90 says:
I'm using milk jugs at the mo, not sure if its just me- but the compost is always moist, with this system, so for me to pour water onto the compost, it makes it too swampy! I pour the water into the bottom part of the planter myself, my tomatoes are growing high : )
Jul 23, 2009. 9:42 PMguy90 says:
Nope, see the part on the milk bottle where the handle protrudes out? well, when I flipped and loaded this part into place, it left a neat little gap, to save me dismantling the contraption when I need to water it. I'm using cherry at the moment, my little sister mentioned the idea of stacking bottles, but I doubt they'd have a lot of light, clear bottles might make good propagators if they were around : /
Apr 20, 2009. 1:00 AMwilson.joe says:
you could drill little holes around the sides of the cap area where the cap use to be to help the sponge exporb water...
Jun 25, 2008. 5:25 AMlharris says:
Hi, Can you clarify, please, "until it breaks"? Until what breaks? Since I don't have foam, I will be cutting whatever needs to break. Are you removing the neck of the jug? It appears intact in the picture showing the top being inserted in the bottom. Thanks for any help. Lana
Jul 13, 2008. 2:45 PMandyhuntdesigns says:
I think it means until the green floral foam breaks off into the neck of the jug
Oct 1, 2008. 11:09 AMjany says:
Ahhh. I get it now.! I think I will try that with a small ivy plant. Thank you so much for your input again. Jan
Aug 10, 2008. 7:23 PMjany says:
I would like to see more pictures. Im confused about the top part of the jug and the bottom half. Why is that ridge in the bottom of the jug so important?
Feb 20, 2007. 4:52 AMgowithflo says:
I just started a gardening group . . . want to join? Add this instructable please!
http://www.instructables.com/group/reapwhatyousow/
Oct 20, 2006. 6:04 PMboocat says:
This seems neat! I'm eager to try it next summer. Thanks.
Jun 5, 2006. 4:06 PMearthgirlemi says:
What a cute way of using up plastic bottles...I'm going to try this a.s.a.p.
May 8, 2006. 3:58 PMBrother_Bear says:
Great instructable short and sweet. :) A tip to take into consideration though is to tape or paint the outsides opauqe to prevent algae growth and promote healthy root development.This is because algae like light and suffocates the roots by covering them and stealing nutrient etc. And the roots become stunted on some plants because they strive to avoid the light and by doing this they bunch up in the middle of the planter. But like i said great tutorial iam gonna make some for my Daturas(Angel trumpets,thorn apple and Bella Donna)
May 25, 2006. 4:06 PMRifeHeretic says:
Bella Donna isnt a Datura, though it is a Baneful herb and both are from the same family and contain some similar trptophans
May 23, 2006. 9:36 PMgbell12 says:
OHHHH.... wow, I had to stare at that a long time to get it. You're making a plug out of the foam for the funnel part of the milk carton. Can you maybe put a picture of that part in? Also, are you meant to keep the jug handle full of water?
May 13, 2006. 1:14 PMJunkyard John says:
there is an easier way to make self watering plaunters. Fill a cup up with water and stick the end of a piece of string in it. Connect the other end of the string to a regular planter. Use more strings for bigger planters. Great instructable, though :)
May 12, 2006. 11:08 AMBrother_Bear says:
Think nothing of it :)
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:aperkins01096(http://www.dabblings.net)
Network administrator, solar heat and electricity enthusiast, avid gardener, scrimshander, blogger, and more. I keep busy updating dabblings.net, makeheat.com, scrimshaw.com, gardenhacker.com and oth...
more »
