Quick, Easy, & Cheap Amplifier for Your Iphone
Published
Introduction: Quick, Easy, & Cheap Amplifier for Your Iphone
When you don't have an iHome or speaker systems this works a great substitute!
Step 1: Materials
Ruler/ tape measure
Box cutter
Marker
Empty toilet paper/paper towel roll
2 solo cups
1 piece of paper
Step 2: Remove Your Phone Case
Step 3: Getting Phone Measurements
Locate your speaker
Measure the length and width of the side of your phone containing the speaker
Write down your measurements on the piece of paper for later
Step 4: Measure Toilet Paper Roll
Locate the center of the toilet paper roll by measuring it’s length and dividing by 2
Using the marker, draw a dot at the center of the toilet paper roll
Step 5: Mark the Width of Your Phone on the Roll
Starting from the dot you just drew, mark a line about half the length of your phone on each side towards the edges of the roll (Right and left of the dot).
Step 6: Cut the Roll
Using the box cutters, start from the center dot and cut outwards to the line you just drew on each side
To make cutting easier, move the box-cutter in a saw-like motion AWAY FROM YOURSELF
** CAUTION: DO NOT CUT YOURSELF– ALWAYS CUT AWAY FROM YOURSELF AND OTHERS **
Step 7: Make a Full Phone-sized Holder
Make two small cuts perpendicular to the line you just cut (about the width of your phone)
Fold the cardboard back about 90 degrees (be careful not to fold all the way) , creating a “lip” on the toilet paper roll
*This will form the opening that your phone will sit in later on*
Step 8: Mark Hole on Cup for Toilet Paper Roll
Place one cup upside down and position the end of the toilet paper roll to the bottom of the cup
Trace around the toilet paper roll on the cup
Step 9: Cut Out the Hole
Using the box-cutter, cut out the circle that you just traced
(Again it will help to move the box-cutter in a saw-like motion)
*tip: the more accurate your cut is to the size of the toilet paper roll, the louder your music will play*
Step 10: Repeat Steps 6, 7, and 8 to the Other Solo Cup
Step 11: Connect All the Pieces
Insert the ends of the toilet paper roll into the holes at the bottom of the solo cups
Step 12: Place Your Phone Into the “lip” on the Toilet Paper Roll
Step 13: Finale
Select your favorite song
press play
JAM OUT!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
