Quick fix for broken laptop hinges by lampshade74
The hinges on my Inspiron 300m are worn out. Being cheap and not wanting to fork out > $100 for new hinges I came up with this simple workaround with velcro strips and a brace- mightn't look the best but it works!
Step 1: Attach velcro strips
Get some velcro strips and attach to the bottom of the laptop and the back of the screen. In retrospect I would probably go for wider strips than I have now.
rclark19 says: Jan 11, 2013. 11:52 AM
i used a regular iron wall joint for mine (like pictured but smaller) with velcro worked for me thank you!
rojelees21 says: Jul 1, 2012. 8:38 PM
Much better if we can put a Hinge on the elbow of the metal strip or Brace so that we still can open and close it all over. Anyway, thanks for that good reference :)
jsmith99 says: Jul 2, 2011. 8:02 PM
LOL!!! That IS cheap...but I think I'm going to use it. Thanks!
toogers says: Mar 23, 2010. 3:52 PM
you could also make a metal pocket on the bottom, just slip the L-bracket in.
falcotheimpaler says: Oct 14, 2009. 8:46 PM
This is a great idea, and i'd probably use it, if not for the fact thatyou can tighten laptop hinges with a pair of pliers, if you remove thehinge cover
mjshark says: May 27, 2009. 8:42 PM
Poor Man's Wobbly laptop fix: After putting up with my Dell E1505 Inspiron's laptop wobbly lid for a few months, I found the above fix on this site. However, I did it slightly differently. At my local hardware store I purchased a 3/4" wide by 16" long metal strip for about 1.50 and some heavy duty velcro grey strips for about 4.50. So, for $6.00 problem solved! All I did was bend the last couple inches of the strip around the top of the laptop, ran it down the back, and then bent it 90 degrees at the bottom where it goes underneath my laptop by about 4 inches. I used 4 strips of velcro to securely hold it in place. So far, it works great! See my 3 uploaded pictures!
Laptop repair bottom velcro (1).jpgLaptop repair back metal strip(2).jpgLaptop repair top hook.jpg
ReCreate says: Jun 10, 2009. 7:14 PM
Weird...My 15 Year old Laptop still feels like new :S
sassafrass says: Oct 16, 2008. 7:45 PM
Hey thanks, this looks much better than the duct tape I've been using!
Marble of Doom says: Sep 8, 2008. 1:15 PM
Thanks, this is just what I need to fix my old laptop!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
