loading
Picture of Quick fix for broken laptop hinges
The hinges on my Inspiron 300m are worn out. Being cheap and not wanting to fork out > $100 for new hinges I came up with this simple workaround with velcro strips and a brace- mightn't look the best but it works!
Step 1: Attach velcro strips
Picture of Attach velcro strips
Get some velcro strips and attach to the bottom of the laptop and the back of the screen. In retrospect I would probably go for wider strips than I have now.
ksourmoonB5 months ago
..Now if only this worked.. ;-; but my hinge is broken on the inside and if I move my laptop the fan catches the broken metal pieces.
rclark192 years ago
i used a regular iron wall joint for mine (like pictured but smaller) with velcro worked for me thank you!
rojelees213 years ago
Much better if we can put a Hinge on the elbow of the metal strip or Brace so that we still can open and close it all over. Anyway, thanks for that good reference :)
jsmith994 years ago
LOL!!! That IS cheap...but I think I'm going to use it. Thanks!
toogers5 years ago
you could also make a metal pocket on the bottom, just slip the L-bracket in.
This is a great idea, and i'd probably use it, if not for the fact thatyou can tighten laptop hinges with a pair of pliers, if you remove thehinge cover
mjshark6 years ago
Poor Man's Wobbly laptop fix: After putting up with my Dell E1505 Inspiron's laptop wobbly lid for a few months, I found the above fix on this site. However, I did it slightly differently. At my local hardware store I purchased a 3/4" wide by 16" long metal strip for about 1.50 and some heavy duty velcro grey strips for about 4.50. So, for $6.00 problem solved! All I did was bend the last couple inches of the strip around the top of the laptop, ran it down the back, and then bent it 90 degrees at the bottom where it goes underneath my laptop by about 4 inches. I used 4 strips of velcro to securely hold it in place. So far, it works great! See my 3 uploaded pictures!
Laptop repair bottom velcro (1).jpgLaptop repair back metal strip(2).jpgLaptop repair top hook.jpg
Weird...My 15 Year old Laptop still feels like new :S
sassafrass6 years ago
Hey thanks, this looks much better than the duct tape I've been using!
Thanks, this is just what I need to fix my old laptop!
