They need to be shreded to be correctly composted.
If the woody prunings are a small fraction of your compost maybe it is not necesary to buy a expensive compost shreder. You can build a small hand cranked compost shredder.
Remove these ads by
Signing UpStep 1Big bore bit drill
A worn big bore bit drill . You need to weld a rod in the tip of the bit drill. this rod must be aligned with the bit drill's axle.The frame is made from wood. take all the measures and drill two holes in the frame, then put two bearings on it and put the axles into them. Fix the frame with nails or whatever you want.
I use this shreder to chop thin elderberry branches, and that set is enough to do the job and keep things simple.
But if you're looking after improving the maximium potential of a hand crancked shredded, then there's plenty of room for improvement, I think that's the work for another instructable.
Thanks for your comment.
There were some on the market years ago, but no longer. I have tried meat grinders to no avail.Your solution is so elegant.Thank you!
