All you need for basic protection is:
- a large plastic tablecloth (the cheap, thin disposable kind; it can be used- save one from being thrown out after a function, give it a clean and a new lease of life!)
- scissors
- a couple of clothes pegs.
- you may also need a bit of sticky stuff such as Blu-tak or masking tape
A few other things that may be useful, too - see the notes in Step 3.
Remove these ads by
Signing UpStep 1Cut the tablecloth and fit to basin area
Lay one half over your basin and estimate how big a hole will be needed to fit over the basin.
Fold the piece in half and cut out a semi-circle, a little smaller than you think would fit half the basin (you can always cut out more if you need to). Put it over the basin and see if you can still use the taps. Trim if necessary.
If you have a separate splashback, tuck the top edge of the plastic over it to hold it in place. Otherwise you may need to use some sticky Blu-tak or a bit of masking tape to hold the plastic up (check that it won’t damage your wall surface). You may find that by putting your hair dye kit on top of the plastic, it will stay in place anyhow.
Add Comment
