But what if you're stranded on a desert island with no laser printer and you still want to work out a super-quick printed circuit? What then?
(OK, honestly, I just find it a bit of a hassle to fire up Eagle, etc just to make a quick and dirty battery-charger circuit.)
Here's a start-to-finish home-etching-with-Sharpies mini-tutorial. It's basically "draw the circuit with sharpies, then etch" but the gold is in the details.
Remove these ads by
Signing UpStep 1Stuff You'll Need
Copper clad board
Ruler and matte knife to cut it
Scrubby pad to shine it
Three (3!) Kinds of Sharpie: Ultra-Fine, Fine (Regular), Chisel-Tip (Wide)
An empty piece of protoboard (the secret ingredient)
Etchant
Drill and bit
Components
Soldering Iron
Pen and paper for working out the circuit layout
Anyway, the PCB techniques you present here are excellent ideas, thank you for taking the time to post them online so the rest of us can learn from it.
I am impressed by your creative use of perfboard, both in marking and especially drilling. I was half expecting you to say "okay, now guess at where you thought the pins were," but no, you give us a very good tactic instead.
I may not do PCBs by hand anytime soon, but now I am armed with a proven plan of attack when the need arises. Hooray for The Real Elliot! :)
also dude down there `´ `´ dont drill it, cut the pins off and solder like they are smd's, takes some practice, but driling is a pain without the proper tools
The non-fragile bits I have been using look like regular 1/16" bits, but read 0.039" in the calipers (5/128"?!?). They seem to be stronger than the carbide ones, and are a good size for DIY holes.
Or skip the drilling and the mirror-imaging entirely, and do everything top-mount. (I smell another instructable coming...)
hot = might as well not really be there because its saturated with heat
for a heat sink to really work it has to dissipate more heat than its absorbing, that way its wicking the heat away into air
try replacing that copper pcb with a flattened down "slot cover" from the back of a pc and see if you notice any difference, i bet you will :)
