Step 6Draw Pads and Connect the Dots
Draw wider dots around each of the fine-point pin centers. These'll be what you solder your parts onto later.
Then draw the circuit out. Here the usual width rules apply -- make the traces as wide as you can without compromising your design. Thin, ultra-fine point traces may be necessary if you have to snake in between pins. Otherwise, regular sharpie is a good width for most traces.
If you've got any close trace-to-pin places, feel free to draw out the traces first and make asymmetrical pads to work around it. You know where the pin-centers need to be because you marked them with the perfboard.
Add Comment
