"Quicksilver" Retro-Future Scooter from appliances and scrap metal
Step 6Dash board
Dash board
  • last photo ←
Time now to look at the instrument panel. The original was a blocky, purple plastic thing, that the world is better off without. Rich suggested that we try to make a nixie tube speedometer. I couldn't think of anything that would be cooler than that so I went ahead and mounted everything up so that he could route the original encoder through a contraption of his own making. I used the original fuel and temp. meters, but hacked them into antique voltage meter bodies to maintain the vintage feel of the machine. A lot of hours went into these little details. The meters had to be mounted on a piece of plexiglas, hung behind the face plate with aluminum standoffs. I cut out new meter scales from pieces of plastic and drew in the scales by hand. Then some LEDs were added to illuminate them. I found some old Russian nixies on the internet and mounted them behind a slightly larger voltage meter body.
Update: I just realized I never posted an image of the final instrument cluster. The speedometer worked out quite well, though the temp meter reads backwards, doh! I suspect it is a simple matter of reversing the wires but I have not had the motivation to pull the panel apart since I finished it.
3 comments
Nov 1, 2011. 6:57 AMcircuitmage says:
OMG. The design is awesome. And the display is...WOW. Great work. One of a kind.
Jun 3, 2008. 7:35 AMnicko says:
Dec 28, 2007. 12:04 PMJiggsy says:
First off, LOVE the scooter! It's everything a Vespa is and more! If you put this into production, I want to be on the waiting list! However, I do have one teeny little comment. Shouldn't you be concerned with the nixie tubes breaking while driving? Although a cool design element, I just figure they're too expensive and fragile to be put to use in a scooter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:nemomatic
I am a kinetic sculptor who works from found materials.
