Quieting Down a Cheap Alarm Clock
Introduction: Quieting Down a Cheap Alarm Clock
I'm going to guide you through the steps you need to take a really cheap battery-operated alarm clock and make it much much quieter.
You'll need:
A plastic alarm clock run by a AA battery.
A very small screwdriver that fits into the screws that hold the clock's case together. Probably a very small Philips-head screwdriver.
A small slotted screwdriver.
Lightweight oil, like 3-in-1 oil, sewing-machine oil, or watch oil.
You may need a pair of pliers - jeweler's pliers are nice.
A quiet place to work where you won't lose the little parts.
What we're going to do is take the clock apart, put a drop of light oil on the parts that clatter every second, and put it back together. The oil should keep it quiet for quite some time. Maybe as long as you can expect these cheap little clocks to last.
Step 1:
First, pull the knobs off the back of the clock. They're probably held on by friction or by tiny springy plastic "arms" visible in the little hole in the knob. You may need to push the plastic parts together with a screwdriver or pliers - or you may be able to just pull the knobs off.
Step 2:
Did I remember to take the battery out? Take the battery out. Now you can unscrew the little screws that hold the case together.
Step 3:
Be careful now. There are thin wires soldered to parts on both sides of the case. Don't yank on them, or you'll have to solder them back when they pull off. And there's a little coil of copper wire - very very thin. If you even think about touching that, your brain waves will break the wires, and you won't be able to fix it.
Step 4:
The clock movement is the plastic module with wires going into it. We're going to take the back of the movement off. It's held on by clips molded into the plastic. Mine has two kinds of clips. One kind is sprung by pushing the black clip away from the clear top.
Step 5:
The other kind is sprung by pulling the clear clip off the black back. They're all brittle. If they break, you're probably still going to be able to put your clock back together, but be careful.
Unclip all the clips, carefully, and then pull the clear top off.
Step 6:
Here's the movement with the back off. Don't touch those copper wires.
Step 7:
There are little dimples in the inside of the clear piece. They're bearings for the gears. Now put a tiny drop of oil on each of those dimples.
Step 8:
On my clock, there's a gear that comes off first - you can see it sitting on the table in back of the clock here. There's a tiny gear attached to a tiny magnet that's revealed by this - I'm holding it in needle pliers in this picture. Lift it out, don't touch the copper wires that are nearby.
Step 9:
Where that tiny gear with the magnet was sitting - there's a little bearing hole that the gear sits in. Put a drop of oil in there. This is the place where the oil really helps quiet down the clock. Now put that gear back where it was.
While we're here, put a drop of oil on the teeth of that gear.
Step 10:
Put the remaining gear back into place and snap the cover back on the movement. Now close the clock up carefully - make sure you don't pinch the wires. Make sure the snooze button (if it has one) is back in place. And reattach the screws and knobs. You're done!
Did you put the battery in?
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
This is so simple but effective, thanks, just saved me a trip to the shop to take the clock back, I really like it as well so was a little upset about the prospect. Thanks again!
Fine up to step 4 - bending back the lugs. But when I attempt to lever up or pull up the cover to remove it there is considerable resistance and I'm scared of breaking something. I've already removed the two screws holding the clock-movement module to the case (because these appear to go through the module cover as well) and cannot see any other screws to remove or lugs to bend - though the level of resistance I'm experiencing suggests one or the other is still present. It's an Acctim 14117; photo of module attached. Any advice much appreciated.
Thanks you very much for this post. I bought a second hand clock for 1 euro today for my son and almost threw it away because of the noise. Thanks to you he now has a nice AND quiet clock!
I never would have guessed that this would work, but it does! Many thanks for posting this (and thanks for the warnings about the copper coil; I was mightily tempted to play with it ;-)
Thank you! This worked really well. I used olive oil.. the ticking sound is now much much quieter.
Thanks.This brought the volume down to acceptable levels.Removing the second hand didn`t make much difference on my clock.
p.s., i'm just curious why you can't touch the copper wire. i like ot know why??? about things people say.
Oh, you can, but you just have to be very very very gentle. The stuff is delicate. Mind waves can probably break it!
wow that was great thanks! i'll try it on the next clock i buy. unfortunately i threw the other one away because i was going crazy, lol, i tried to quiet it, but it wasn't quiet enough.
