Quilled Vintage Telephone Keychain
2,994
13
12
Published
Introduction: Quilled Vintage Telephone Keychain
About: Computer Engineering student | Fond of reading | Loves to cook | A DIY enthusiast | A night owl
Here is the tutorial on making this cute vintage telephone keychain. :)
Step 1: Things You Will Need.
  • Paper quilling strips.(3 mm and 5 mm )
  • Quilling tool.
  • Glue.
Step 2: Telephones Main Body.
  1. Before quilling the coil, glue together 6 strips of quilling strips.
  2. Insert a 5 mm paper strip in a slotted quilling needle.
  3. Keep quilling till you make a tight coil of the desired size.
  4. Pinch off the rounded sides to a point, and make a square as shown.
  5. Gule the end and secure it.
Step 3: ​Using Your Finger Gently Push From the Center of One Side of the Coil to Form a Cup Like Structure.
Apply glue on the inside.
Step 4: Telephones Receiver.
  1. Insert a 3 mm paper strip in a slotted quilling needle.
  2. Keep quilling till you make a tight coil.
  3. Glue the end so that the coil is secure.
  4. Using your finger gently push from the center of one side of the coil
  5. Apply a coat of glue on the inside of the cup and allow it to dry
  6. Make two such cups of same size.
Step 5: Make a Small Pipe Out of Paper Strip.
  1. Join the two small cups with glue at the two ends of pipe.
  2. Make a paper spring.
  3. Join all these parts together.
Step 6: Finally Glue the Telephones Dial.
Step 7: Join the Chain.
Your key chain is ready!
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    12 Discussions
    This is waaaay to cute!! When I saw that I was like "how did she make that"!!!
