Introduction: Chevron Ombré Quilt
Picture of Chevron Ombré Quilt
Chevron ombre quilt using blues!
Step 1: Choose Fabric
choose fabrics you like! As many or as few
Step 2: Cut Squares
cut squares, I did 6" but you can do larger or smaller depending on how big you want your quilt
Step 3: Pattern Layout
decide how you want your chevrons. Then lay squares together,fabric print together. For example in my quilt I wanted mine to be dark blue to light blue to white to gray to black. Therefore I put the dark blue squares together with the light blue, the white with the gray and so forth
Step 4: Sew
sew the squares together on all 4 sides using a 1/4" seam
Step 5: Cut
cut the squares on the diagonal, unfold, then spray with starch and iron them flat
Step 6: Layout and Sew Again
layout in a chevron pattern and sew together again until the whole quilt is done
Step 7: Add Back and Bind
choose a backing, then bind together!
About This Instructable
217views
2favorites
License:
More by ShannonM11:Rainbow Tie Dye for TotsChevron ombré quilt
Add instructable to:
