loading
Step 5: Join Your Blocks
Once you have a big ol’ stack of quilted blocks, you actually get to start joining them together!
To join squares, place two blocks, right sides together. Carefully pin JUST the top layers together. You do NOT want to sew through your backing fabric. I found it easiest to either pin or press the backing out of the way while I stitched the tops together.
<p>Hi Abby, I think your idea is great. I was going to adopt it for our first quilt, a large one, 61.5&quot; x 55&quot;.</p><p>There is just one thing though. I just spoke with the company who sells the quilt design and pieces and was running by your idea with them.</p><p>They were recommending we not do the quilt in sections.</p><p>Their reason was that there is a big risk that the blocks/panels won't fit together after quilting each panel. There is pulling etc. as you quilt the appliques and other stitching.</p><p>So what would you do if things didn't line up by an inch or more for each panel?</p><p>This is a design where you would notice this right away.</p><p>Thanks!</p>
<p>I'm not Abby but thought I could help anyway - this technique is great but common sense says it's not going to work on a very precise design where lining up the blocks perfectly is vital. I have quilted king size quilts on a regular machine, it's tedious but it's really doable with patience and large binding clips. Use Abby's technique for a different quilt than the one you are doing - if the company does not recommend it believe them. </p>
<p>Thanks Ninzerbean for your response. This is a very difficult decision indeed because of the special circumstances at play here.<br>The person doing the quilting will have had no experience whatsoever doing quilts before. It's the country where this is being done.<br>Can you imagine them doing a quilt of this size in one piece, first going over dozens of intricate appliques and then quilting the rest?<br>Because of this I have decided to make a compromise. Instead of doing four separate panels and joining them together, we will join just two (panels 1+2 and panels 3+4).<br>Keeping our fingers crossed. :)</p>
Love the idea, an how U make it sound so much less complicated.. unlike how complicated some of the books I've read make every step sound so much harder then it really is, i hate dealing with the confusion of it.... thank you for sharing your idea, ima gona have to try this next time i start a new quilt
Thank you so much! I'm working on a king sized quilt, and there is NO way I'm gonna fit the whole thing in my machine for quilting, and this seems like the perfect way. I think I'll do it in long rows, though (less seams on the backing at the end.
P.s ill be doimg it ALL by hand!!!
Hi im juat about to start making a quilt for my son. The irst one made was a quilting kit! Which was lovely but i think i would really love to have a go my self! I lobe the sound of the way you made yours so im gonna give it a go! Wish me luck
<p>Thank you so much for this instructions how to quilt as you go. I always thought that quilting was too difficult, but you make it much easier.</p>
<p>I am assuming that once you have all your blocks put together that you can add a border before binding too!?</p>
<p>You might want to check out www.quiltingonthegrid.com for a way to make beautiful quilts with just a sewing machine! I have done so because my wife developed this technique and got a U.S. patent on it this year.</p>
Warren I don't know how open you are to tips that will improve your conversion rates on your web page (conversion rate = how many &quot;browsers&quot; become buyers). There is too much text on your page, people need simple info, presented in small chunks, with space around it, with click through links that provide more info and an option to purchase. A good web designer and marketer is worth the money and will repay in sales. Look for a good web page, and check for the designers name - google for contact details. Best wishes.
<p>Very simple and straight forward instructions - the best I've seen so far. And you are not limited to just the size of your single block, you can sew 4 or more blocks together first and then measure the batting and backing to fit. Or you could first sew one row of blocks together and then quilt them as you go so you have only 4 or 5 seams in the back to deal with. I hope I made myself clear. </p>
<p>Yes, Yvonne - thank you! :-) I think that would be even easier! :-) </p>
<p>I don't understand the second paragraph of step 7.</p>
<p>Couldn't you sew from the front along the seam, with a zigzag stich or other design to sew the back closed? I think It could work if it was incorporated in the overall design from the start. what do you think?</p>
You can, absolutely. I've just always been awful at lining up that sort of thing well enough... For me it would take a lot longer!
<p>This is fabulous! I'm off to the fabric store right now for batting to get my 2 pieced- but-not-sewn-or-quilted UFOs done! Thanks so much</p>
<p>I am making my 1st quilt and your instructions with photos! :) and the tips about the seam allowances were so very helpful! Thank you!</p>
<p>Thank you for this!!!! I am super excited now, to try this!</p>
<p>I love how your quilting is part of the visual appeal as well as the piecing</p>
<p>Wonderful tutorial, thank you for posting it!</p>
wow this is amazing i have been struggling with the bulk of things for so long now your a lifesaver
This is wonderful and I agree with the others, this is the best instructions I could find. <br> <br>You say that you should have made something with a half inch seam and not a 1/4. I can't really see how the block can be made with the outside a 1/2 unless it is just a one fabric edging. (I am doing peaches and cream which has two different halves to the block) I think I would make the backing blocks with a inch seam allowance incase things go slightly askew. This could be cut back before sewing together. Am I right??
Actually, now that I'm looking at my pictures, I think I did 1/4 on the backing squares as well. It was a huge pain in the butt.
Everyone is so sweet, I'm glad that my instructable helped! <br> <br>I think (it's been a while since I wrote this, so trying to remember) the problem I ran into was that my seam allowance around my blocks was only 1/4 for my top, and between getting everything lined up it was just too little, made things a giant pain. I'd definitely err on the side of having more seam allowance than necessary and trim once you've got the blocks together.
I'm getting ready to make a bed quilt for ME. I'm definitely going to follow your pattern of assembly! I just finished a sofa sized quilt for my hubby, and I could NOT get a handle on the bulky mass, or move it around to free motion quilt it. The center block looks like pinched scribbles cause I couldn't get it to move around. The rest is just straight line stitching. I can't wait to really have some quilting fun! Thanks
Very nice. This will be a great way to do project quilts for school and scouts. Everyone can do their own piece and quilting then trim and tie it all together.
I also watched several You tubes and looked at sites and this by far the best!
Thank you so much! I have viewed probably 20 tutes on YouTube, and 5 others on various websites...even bought a book on QAYG, and YOU NAILED IT! Thank you Thank You THANK YOU! My first quilt project was a full size totally machine quilted scrap strip quilt blanket for the daughter. My next one will be a rainbow disappearing 9 patch for ME, using your method. You do BOMB.
I just love this idea but could not get these directions to print. I have tried to download to PDF file and still won't let me. <br>
How can I print these directions. I have tried to download to PDF file and still won't let me. <br>
Yikes! Hand sewing? Is there an option for machine sewing it?
You don't *have* to hand stitch it necessarily. If you line everything up right and use a nice deceptive stitch, you could very easily do this on machine. I just like hand sewing a lot, and have an extreme hatred of trying to line things like that up! I also was going for the invisibility that you get with hand sewing.
Decorative, I mean. Haha
About This Instructable
725,849views
255favorites
License:
Bio: My name's Abby, and I make things. Lots of things. Sewing is my favorite activity, and any project that involves fabric is like a ... More »
More by abbyholverson:Quilt-As-You-Go Quilt Children's Doodle Quilt Cathedral Windows Quilt Squares
Add instructable to:
