Half square triangles are another important subunit in making quilt blocks and quilts. A half square triangle block is a square made of two different fabrics, so that each fabric forms half the square joining along the diagonal.
This instructable shows how to construct a half square triangle block from 2 squares of fabric so that they are ready to be used in a quilt. Calculating the correct size of starting square to end up with the desired finished size is also discussed. After following this instructable a student should be able to construct half square triangle units as used in many traditional quilt blocks.
Remove these ads by
Signing UpStep 1: Materials
washable fabric marking pen or pencil
ruler
sewing machine
thread
or needle and thread if you hand piece (i.e. no sewing machine)
Iron
Ironing board
Scissors
Rotary cutter (not absolutely necessary, but makes cutting squares much faster)
My sewing instructions will all be for machine piecing, but the basic idea, cutting, pressing and layout are the same for hand piecing.
Visit Our Store »
Go Pro Today »
The block is from the Swoon pattern which simply uses squares, half square triangles and flying geese, so you could make this by following my already published Quilting Basics Instructables!
The finished wall hanging measures 24" x 36"
You may want to edit this Ible and add these pictures as Wilgubeast suggested.
Personally, I think the close-up picture would work perfectly as the Intro picture.
Good Luck in the Challenge!!! ;-)
How to, make, sew, DIY, easy quilting, technique (etc).
This will increase the number of visitors to your wonderful instructable. ;-)
ha ha ha... lemme help you out with that horn business. ;-)
