loading
Step 3: Press the seam, cut the blocks apart and press again
Heat your iron up to cotton setting (3 spots), or a lower setting if you have used polyester thread. Most quilters recommend a dry iron for this i.e. no steam.
Put your pair of squares on the ironing board and then place your iron on the seam and press down on it for a few seconds without sliding it around.
Cut along the marked line using scissors or your rotary cutter & ruler, this will leave 1/4" seam allowance between the stitched line and the cut edge.
Put your pairs of triangles back on the ironing board with the darker fabric on top.  Now open the seam of the first pair (like a book) by folding the dark fabric over the seam and press it back in place, again try not to slide your iron about more than necessary as this can distort the fabric.  You want the fold of the fabric to be as close as possible to the stitches. Repeat for the second pair and you will have two squares each made of two fabrics.
You can now trim your block to be absolutely square if required.
I've made about 6 or 7 quilts in the past 15 years, but all have been with blocks. Lately I've been looking at different patterns and they seemed alittle hard. With these instructions, not so much. What I thought would be a challenge now seems do-able . Thanks for giving great instructions and the confidence to do it. Would appreciate any other quilting tips you might have up your sleeves. Thanks: )
Thank you for your kind comments. I do have some more instructables for basic units planned, I just need to find the time to take the photographs!
This is an excellent write-up. And your learning objective is so concise! Looks good. Don't forget to show us the finished project (if there is one) in the comments or in a new Instructable.
Thank you! Here are two photos showing the finished project a Spring/Easter Wall hanging for the lobby at work.&nbsp;&nbsp;<br> <br> The block is from the <a href="http://thimbleblossoms.bigcartel.com/product/swoon-pattern-142-pdf-pattern" rel="nofollow">Swoon pattern</a> which simply uses squares, half square triangles and flying geese, so you could make this by following my already published Quilting Basics Instructables!<br> <br> The finished wall hanging measures 24&quot; x 36&quot;
Beautiful work! <br><br>You may want to edit this Ible and add these pictures as Wilgubeast suggested.<br><br>Personally, I think the close-up picture would work perfectly as the Intro picture.<br><br>Good Luck in the Challenge!!! ;-)
Just a suggestion, but you might also want to add more keywords during the edit, such as:<br><br>How to, make, sew, DIY, easy quilting, technique (etc).<br><br>This will increase the number of visitors to your wonderful instructable. ;-)
Thanks for the advice bajablue, I guess I tend not to be very good at blowing my own trumpet! I shall take a better detail picture showing the HST in situ and use that as you suggest.
You're so welcome.<br><br>ha ha ha... lemme help you out with that horn business. ;-)
Very smart technique!
Thanks, it isn't difficult to do, but so much easier to explain with photos as well.
About This Instructable
2,483views
23favorites
License:
Bio: Wife of one, mother of three & now a grandmother too! I enjoy making things and cooking edible things and eating them. aka on IRC as ... More »
More by lizzyastro:How to Make a Reversible Quilted Coffee Cosy Quilting Basics : 4 Patch Block Travel Case for phone, passport & ebook
Add instructable to:
