I looooove to sew - absolutely dreaded to HAND sew because I always had trouble with where my knot would end up.
My fellow sewers feel me. I'd try to tie off my thread by looping it around the very end of the length, on my fingertips, pushing that little knot down tight as near to the end of my thread as I could get. And woe-was-me if I was sewing with a single strand and had to try to tie a double knot. Getting that second knot to lie right on the first was always a struggle. UGH!
So, here's an Instructable about a trick that saved my sanity and opened up a new world (I could have never started to do Hawaiian quilting, which is all handsewn, without it) of enjoyment.
Remove these ads by
Signing UpStep 1Step 1
Hold an end of the thread between your index finger and the needle, near the sharp end.
A point to check: Make sure the thread that you've wound around the needle isn't unwinding before it gets pulled the entire length. Leave a little extra thread tail during Step 1, so that you can see it hanging out once you've moved the wound section from the finger of one hand to in between the fingers of the other, in Step 3.
Did that help?
thanx
Learning this technique absolutely changed the way I looked at hand-sewing 180 degrees.
