iImage Information
Quinzees are much faster & much easier to build than igloos. We built this one just for fun, but we've also made them for sleeping in while winter camping.
Step 1Find a spot & start shoveling
iImage Information
Where you build your quinzee is pretty important. If we had needed quinzee to sleep in, we would have found a nice sheltered spot, on level land. We opted to build ours on a lake instead. Now, frozen ice conducts heat much better than frozen ground, so sleeping on a lake will draw your body heat away much faster. That really sucks. Not a good choice for over-night campouts, but were just building this one just for fun, so it wasn't an issue.
Where ever you choose to build yours, start by digging out all the snow from the area that your quinzee will sit. Then shovel it all right back. Moving the snow like this will cause it to settle out and give your quinzee a good solid base.
dont mean to be a bother but it says that he built the fire outside the quinzee. he built it within the walls. XD
Nice to know you're getting to enjoy some snow in the UK!
By the way, there's even a band called Quinzy!
Just prepare for 1 minute of horrible stenches if you try that.
1. Never Ever dig into to a quiznee by yourself. Always have a friend outside helping who can dig you out.
2. While digging stay with your legs underneath you facing down, if it collapses it gives you a chance to stand up. Snow is REALLLY HEAVY
3. After piling up the show, let it settle for a few hours. The books I read suggest 3-6. Pile up snow in the morning , eat lunch, then dig.
Thank you
Having slept in quinzees built pretty much on every kind of terrain over the years, I have found that ice makes an incredibly efficient heat sink and will rob you of any warmth generated from being in an enclosed space. The only remedy to this is having a very efficient thermal break between you and the ice; such as a non-inflatable sleeping mat, pine boughs or several wool blankets.
It is much better to build a quinzee on top of ground and line the bottom of the quinzee with pine boughs.
Cheers !!
Pine boughs - or preferable fir or cedar boughs which have softer needles - work well as a sleeping mat. Wool blankets are always a great winter camping option. They'll keep you warm even if they are wet. I've also hauled in 1-inch rigid foam insulation cut into foot-and-a-half squares of to sleep on. It's a bit bulky on the toboggan, but it sure works great!
me and my friends do it all the time. we actually got a 5 foot fall once all the way around and we were able to sit upright in are quinzee. and for fun we laid in some plywood and a tarp. we even got a torch (i dont small torch i mean this thing shoots a 4 foot flame) and made an ice layer on top and bottom.
Another tunneling idea: have one person start at the top, and one at the door, and have them dig a chute until they meet. It should follow the slant of the quigloo wall, and be a good foot thick (at least). Once the top and door person's tunnels meet, the top person hollows out the quigloo from the top down, sending the snow down the chute. The door person then clears it away from the door, making new mounds that can be carved into walls (or a kitchen, if winter camping.) The top gets plugged up with snow blocks before the quigloo is too unstable, and the top person says inside hollowing out until it is big enough for someone else to come in the door and help hollow. It took us less than two hours to hollow this way, and make a space big enough for four people to sleep comfortably.
