Step 4Prepare the project box
I started by drilling 4 holes in the box top for the LEDs (Photo 1). Push the LED wires through and hot glue them on the underside of the lid. This holds them in place and helps keep the wires separate. You'll notice that LEDs have one flat side. This identifies the negative wire, so try to orient all of your LEDs the same way (Photos 2 and 3).
Next we need to add the switch. This turns the entire unit on and prevents it from being accidentally triggered while in storage. I used my Dremel to carve a hole just big enough for the switch. However, it wasn't very pretty so I added that thin rubber adhesive pad you see in the picture. The switch was hot glued on the inside of the box (Photo 4). Take about three inches of single conductor wire to extend the connector of the slide switch on the inside of the box. This will make it easier to attach to the circuit board later (Photo 5).
Finally, we need to make holes for the Easy Button wires. We need five holes - one for each Easy Button and one for the reset switch. I wanted it to look nice so I used LED holders to plug the holes. My wire was a perfect fit for the metal holders (Photos 6 and 7).
Add Comment
