Step 5Assemble Reset Button
Cut a piece of PVC pipe about 4-5 inches, long enough for your hand to comfortably fit. Take one PVC cap (cap "A") and drill a hole in the center, same size as your wire. Take the second PVC cap (cap "B") and drill a hole that is an appropriate size for your momentary switch.
If you'd like, prime and paint the PVC pieces. I chose a metallic silver paint.
Run your wire through cap A, the tube, and cap B, in that order (Photo 1). Now connect your switch (see switch instructions for pos/neg). Push all of the pieces together (Photo 2). Mine was a tight enough fit that I didn't need to glue the PVC pieces to each other, but I did put hot glue inside cap B to keep the switch from moving.
Add Comment
