Video is not working right now(at least for me). Just right-click and hit "watch on YouTube"
The R-SAR (rail-system assault rifle) introduces a new type of firing system: the knetix rail system. This system is rubber-band efficient because there is less friction between the bullet and the barrel, because the bullet does not come into contact with the other ammo and most of the barrel until it is fired. Unlike other guns, this one uses more of a bolt system than a ram system, meaning there is nothing sticking out when you load it. It is very fun to just play around it.
*UPDATED*
Updates include a safety, more efficient barrel, and a more efficient trigger system
Pros:
-contained firing pin
-good power (50-60ft with the rubber bands i used; you can use more)
-very original
-sturdy
-sounds SICK when you pull back the bolt
-8 round mag
-very accurate
Cons:
-bolt will snap if too much pressure is put on it
-uses 3 broken pieces
Enjoy
PLEASE RATE
Remove these ads by
Signing UpStep 1: Outer frames, supports, and trigger *updated*
1. The two outer frames-make these
2. Make these
3. Connect with blue rods to form the stock/handle support (blue rods on handle do not have to be cut but it makes the handle much more comfortable
4. Support-any kind of spacer will work for the middle
5. Make these
6. Connect to form butt
7. Get these
8. Cut rods :(
9. Connect to make trigger
10. Attach supports to one frame, hold onto the other frame
11. Safety
12. Secure tan clip (pic taken after gun was finished)
Visit Our Store »
Go Pro Today »
0.5*
Outstanding effort my friend i give you 5 for this, ive built it, it never jams and is real accurate plz carry on making these AWSOME weapons!!!
