R2D2
8,090
117
Posted in CostumesProps-and-accessories
Introduction: R2D2
The purpose of this Instructable is to provide the reader with a guideline on how I approached building the R2D2 robot. My R2D2 has the following features:
  • Dome Rotation
  • Projection
  • Front and Rear PSI LED’s
  • Front and Rear Logic Boards
  • LED Holoprojectors
  • Audio
  • Wireless Ethernet communication to an existing Lost in Space robot
The R2D2 is stationary and does not have motorization for the leg.
Wiring schematics and movies of the R2D2 in action are below.
Step 1: R2D2 Unfinished Shell & Components
Step 2: Dome Bump / Dome Top Pushbuttons
Step 3: Projector
Step 4: Wireless Ethernet
Step 5: Triggerable Digital Video Player
Step 6: Speakers
Step 7: PLC (Programmable Logic Controller)
Step 8: Dome Rotation Stepper Drive & Motor
Step 9: Stepper Drive Motor Hub
Step 10: Lazy Susan Bearing
Step 11: Lazy Susan Gear
Step 12: Connectors
Step 13: Power Entry
Step 14: Power Supply
Step 15: Relays
Step 16: Acrylic Cabochons and Spheres
Step 17: Stepper Drive/Motor
The dome rotation is controlled via a stepper motor connected to a stepper drive. The stepper drive is an AutomationDirect STP-DRV-4850 that is connected to an AutomationDirect STP-MTR-34066 stepper motor.
The stepper drive is connected to the Allen-Bradley MicroLogix 1400 PLC via a serial cable that comes with the stepper drive. The PLC sends commands to the stepper drive such as position, velocity, accel, and decel. I discovered that the PLC will not always communicate to the stepper drive after a PLC power up was initiated but it would always talk via the software tool for the drive. To figure this out, I connected the drive to the software tool and monitored the communications between the software and the drive. What I discovered is that there a few undocumented commands that must be initially sent that make the communication work every time. The following text commands must be sent one time during the initial communication between the drive and the PLC.
  • QT
  • HRCM
  • SK
  • CM21
The stepper drive requires a power supply to provide power to the drive and the motor circuit. Since I am using the STP-MTR-34066 stepper motor, the PSB24-120 power supply was utilized that you can also be purchased from AutomationDirect.com. To reduce current when the motor is not turning and to allow manual positioning of the dome before a sequence starts, I have configured the motor to have no idle current 2 seconds after the last move.
When a show is started, I set the position to 0 via a software command, this is like a manual home of the dome. Therefore, having the motor current at 0 allows me to physically rotate the dome to the desired start position so the dome can have any home (0) position desired.
Step 18: Dome
Step 19: Body
Step 20: Rotation
Step 21: Logic Lights
Step 22: PSI LIghts
Step 23: Miscellaneous
Step 24: Paint
Step 25: Control
Step 26: Pushbutton Operation
    • Flowers Challenge
      Flowers Challenge
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    3 Comments
    I love Star Wars!! I've been wanting to make an
    R2-D2 but being a teenager I don't have much money to buy and R2 replica. But making it would be awesome!! (Not to mention having the bragging rights of making an R2 it would be a lot cheaper to make one too) anyways how much would it cost to make this?? May the force be with you.....
    Same here, I'm a teenager too!! I've searched the whole web to know how you build the R2-D2 but all if found yet is its body on this link:
    https://www.instructables.com/id/Full-Size-R2D2-on-a-budget/
    I' m searching for how to make its Dome and hands but with no luck till now.
    if you find something let me know too.
    May Obi Wan help you.....
    The R2 pieces can be cobbled together for around $1300.00 but after purchasing the control system parts for it (PLC, Stepper drive, Stepper motor, Dome bearing, Projector, Etc.), you can easily be into it for over $2000.00. Thanks for checking the indestructible out. I hope it provides some help in the future.
