Forget protocol, droid, and mash up everyone's favorite astromech with mid-heels and create the greatest footwear the Empire has ever seen. These R2D2 shoes are the hottest thing this side of Tatooine and they’re cooler than Hoth.
The wide heel of these shoes was removed and replaced with a steel bolt to provide strength and support, but at a fraction of the size. An R2D2 toy covers the heel bolt, and the toes have been decorated with lenses, blue accents, and a blinking red LED to let everyone know just how this droid rolls.
This project follows mostly the same process as Dinosaur Heels, but with a few more additions to take it to the next level. Whether you're dashing to Tosche Station for power converters or just going to the store, these R2D2 heels are sure to give you geek cred faster than you can shut down all the trash compactors on the detention level.
Here's what I used to make mine
tools:
materials:
Ready to save the galaxy in style? beep boop beep!
Remove these ads by
Signing UpStep 1: Materials + concept
The idea is to replace the standard heel with a slender support post, then hide that post with
R2D2: The toys I used had electronics inside that allowed them to light up and make sounds when a button was pushed. Since I wanted to retain these features I could not drill straight through, rather a valley was made in the back of the R2D2 toys that would go around the bolt heel.
Shoes:
I found these brand new shoes for free outside my apartment. How perfect is that?! White shoes = R2D2 awesomesauce!
Bolts: Any 1/4" bolt will work, cut to height.
End Caps: I needed to protect the end of the heel spikes from damaging any floor surfaces when walking. I managed to modify the existing heel caps to work with my new design.
Visit Our Store »
Go Pro Today »
I suspect these would also look good using Daleks. Or maybe a Dalek on one shoe and a Cyberman on the other .... you have raised many possibilities!
ZOMG!
(As for the channel in the back of R2, I imaging backing him up to the blade of a band saw several times would work?)
I considered a saw to remove the back of R2 and get him to fit before I come to the soldering iron. The plastic wall of the toy wasn't very deep, and where the toy was going to connect to the heel was right where the toy's battery compartment was. The R2 unit is sealed shut, so you can't change (or move) the battery without breaking the toy apart. Also, since the heel bolt is round I thought more surface area contact the better.
If there is a "next time", I would like to explore more (better) methods of affixing dissimilar materials, unobtrusively and without 2-part epoxy.
I wanted to try and reuse the same wording, but seems like I missed that one. Thanks for letting me know, it's fixed now.
(Aside from stealing most of the text from step 1, I also shamelessly copied steps 2, 5, and 6!)
