3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RAW, 8 bit, 16 bit, and 32 bit explained
After alot of confusion about the 8bits/channel, 16bits/channel, 32bits/channel, and RAW color modes in photoshop, I finally figured it out, and decided to make an illustration to show how I've understood it.
This is NOT suppose to be a complete explanation of everything related to bit depth and channels, it's only an explanation of the bit depths in photoshop in relation to each other!
Remember, 8 bit, 16 bit, and 32 bit images are NUMBER OF BITS PER CHANNEL! There are basically 3 channels in an RGB image, so that's like 24 bit, 48 bit, 96 bit respectively. That is because one term describes the number of bits per channel, while the other describes the number of bits per pixel. 32 bit often refers to 24 bit, though 32 bit is actually 8 bits per channel, with an extra "alpha" channel (for transparency).
Notes: I based the 16 bit, which is kind of the key here, on experience in Photoshop, 16 bit might be different in other applications, and for other file formats (Like TIFF I think).
Also, I call RAW 12 bit, that is because in most cases RAW image files contain 12 bits of information per channel. RAW differs between camera manufacturers and camera models, so they work in very different ways. Some RAW files are 10 bit, or 14 bit. No "ordinary" camera can output more than 14 bits though.
23 comments
Feb 25, 2008. 7:07 PMgmoon says:
I think you've confused as many people as you've enlightened....
-- Why is the 16 bits / channel bar graph the same size as the 8 bits / channel graph? (and the 12 bits / channel graph much bigger than both?)
-- You should emphasize the difference between total color resolution and bits / channel. The designations of 8 bit, 16 bit, 24 bit and 32 bit color have been used for a long time, and all refer to 8 bits / channel (color) RGB (plus an 8 bit alpha channel for 32 bit color.)
-- Bits / channel is only part of the story. What about color space? --RGB (3 channels), CMYC (4 channels), LAB (3 channels)....etc.
-- Raw isn't limited to 12 bits / channel. Raw is just .... raw data. Some digital cameras have 14 bits / channel. And a 12 bit resolution image can be expanded (or compacted) to fit any channel--sure, it doesn't contain any more real data, but there isn't much point of converting to a 16 bit channel without that expansion (compacting (12 -> 8 bits) would discard data....) So no contrast is lost, but the full range of intermediate gradation isn't utilized on a larger channel.
-- Anytime you add a masking layer, you add another channel (an alpha channel.)
This stuff isn't too complex:
-- Bits per channel == # of bits used to represent each component in a color space (RGB or other color space)
-- Total colors == highest # that can be represented by that # of bits (unless it's floating point, which is a different animal.)
Feb 26, 2008. 4:01 AMgmoon says:
At least include the word "channel" in the title, since (as I said), the terms 8/16/32 bit have been used to describe color spaces/total color res for 12 - 15 years....That alone is cause for much confusion.
But it looks like you clarified much of the text, anyway.
I'd like to comment in more depth, but I gotta go photograph some chump who runs one of those corporate touchy-feely seminars...
Feb 26, 2008. 3:45 PMgmoon says:
Sorry. I've been a professional photographer for over 20 years (with a degree in photo illustration.) And I've also taught photography at both the high sch (private school) and the college level (including Photoshop.) But a resume isn't a valid argument (neither is ignorance.) Personally, I don't care for your tone. Since I don't have anything nice to say, I'm done here....
Feb 27, 2008. 6:05 AMgmoon says:
Yes, no more comments about this (although my original comments still stand, and are accurate.) But good luck anyways....if you choose photography as a profession.
Feb 25, 2008. 7:11 PMgmoon says:
Correction: only 24 bit color and 32 bit color are 8 bits / channel. 8 bit color and 16 bit are lower (usually indexed) color formats.
Feb 25, 2008. 1:52 PMgamer says:
what?
Feb 26, 2008. 12:45 PMgamer says:
oh, lol, i wasnt sure... i do photo editing, but its nothing intense... hehe, i wont even bother trying to understand...
Feb 26, 2008. 2:06 PMgamer says:
i took a look at it, and... i dont get it, lol, i only part i understand is "255 is a binary # for 111111" but u dont even say it in there:P
Feb 25, 2008. 3:35 PMGorillazMiko says:
Quotes that I want to say:
gamer: what?
randofo: This stuff confuses the heck out of me.
But wow, that looks really complicated, amazing how you know this... I would probably go insane trying to do this kind of stuff.
Nice job! :P
Feb 25, 2008. 11:00 AMrandofo says:
This stuff confuses the heck out of me. I've been currently messing around with C++ doing jpg image analysis and I'm up to my neck in bits and bytes.
Feb 25, 2008. 11:23 AMkillerjackalope says:
It's just about how many actual colours there are, using a few of the different save options in photoshop, bringing up the save previewer can really show you a simple explanation, try saving for web to see a simple representation on 256 colours ie: an 8 bit image...
Feb 25, 2008. 2:01 PMkillerjackalope says:
Oh by the way I just writing that instructable on the better low noise imagery...
Feb 25, 2008. 1:39 PMkillerjackalope says:
I was using the gif previewer as an example but you can change the colour modes in the middle of working and see the differences, sorry about being vague I'm not always that good at writing unless I plan it like an instructable or some such... Point was simply that you can actually view the minor differences, though almost invisible to the eye until you get down to lower qualities. The reason I mentioned the saving for web previewer is is has a chart with all the colours in it and you can go between 256 and 2 colours. It only take a small leap of the mind to think if each of the 256 colours in the chart were to represent 256 colours you'd be seeing a 16 bit channel... sorry I have real trouble explaining leaps I make in my own head...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:ELF
