This project was about operating a remote control car by using an input device connected with a computer, for this purpose we had to connect the remote of RC Car with the computer so that when we operate the computer, remote would start its function and car will be operated. Therefore at the same time we had two grounds to play one was software development and second was hardware interfacing.
Remove these ads by
Signing UpStep 1Materials
1-) DB-25 cable (parallel port cable)............. x 1.....................................................................Rs 250
2-) Gender changer (optional).........................x 1......................................................................Rs 100
3-) Bread Board..................................................x 1......................................................................Rs 140
4-) Wires..............................................................2 meter.............................................................Rs 25
5-) Transistor (Mps a06)...................................x 4.(or any general purpose transistor).....Rs 8 x 4
6-) LED's ............................................................,x 4 (two red two green)..................................Rs 4 x 4
7-) materials for soldering..........................................................................................................
8-) RC Car............................................................x1.......................................................................Rs 350 -900
9-)db25 male header/female ..........................x1.(depending upon your cable)..................RS 100
u can find it on college road at "IC Master" u can use any transistor that is feasible for switching purpose or even u can use a generic transistor .....
still if u r confused try
www.alltransistor.com
or try this
http://alltransistors.com/crsearch.php?mat=Si&struct=npn&pc=0.625&ucb=80V&uce=80V&ueb=4V&ic=0.5&tj=150%C2%B0C&ft=100MHz&cc=-&hfe=50MIN&mnf=&caps=
for equivalent transistor or use C828 ......
thanks for ur comment .....
u can still ask if somethink is nt clear
But what if i wanna do this with usb and not serial port ??
its more convenient that u use a usb to parallel port converter it will b easy else the whole code will b changed
Thanks for help!!!
actually in parallel port one can handle each bit saperatly while usb i think transmits searially
