Converting an RC car into a robot is a quick and easy way to get started with robotics. At the very least, when you get bored of playing with your remote control car after three days, you can turn it into a robot that will do all of your evil bidding. Well, maybe not all of it, but at least a sizable amount.
In this Instructable I will go over the bare minimum you need to get started. Think of it as a template for making a basic robot that can be expanded with sensors, code, and additional hardware to do some really amazing things. You can now impress your family, make new friends, and scare your pets with the power of robot magic.
Step 1: Go Get Stuff
You will need:
(x1) R/C Monster Truck (Radioshack #60-646)
(x1) Arduino Uno REV 3 (Radioshack #276-128)
(x1) Arduino Motor Shield (Radioshack #276-131)
(x1) Parallax Ping Sensor (Radioshack #276-136)
(x1) Heavy-Duty 9V Snap Connectors (Radioshack #270-324)
(x1) Size M Coaxial DC Power Plug (Radioshack #274-1569)
(x1) Multipurpose PC Board with 417 Holes (Radioshack #276-150)
(x1) 90-Ft. UL-Recognized Hookup Wire (Radioshack #278-1221)
(x1) Enercell® Alkaline 9 Volt Battery (Radioshack #25-853)
(x1) 6" Heat-Shrink Tubing (Radioshack #278-1627)
(x1) 5-1/2" Zip Ties (Radioshack #278-1631)
Step 2: Remove the Cover
Flip the RC car over and remove the two screws holding the cover in place.
Put these screws aside somewhere safe for later reassembly.
Step 3: Unplug
Unplug the motors from the connectors on the main board.
If your remote control car is hard wired to the motherboard, cut the motor wires loose.
Step 4: Remove the Controller
Remove the screws holding the controller board to the RC car and pull it free.
Step 5: Power
Remove the cover from the M-type power plug and slide it onto the wires for the 9V connector (such that you can twist it back on after you solder the wires).
Solder the red wire to the middle connection tab. Solder the black wire to the outer connection tab.
Twist the cover back onto the plug.
Step 6: Mark and Drill
Place the Arduino atop the bed of the cargo RC car.
Make marks where the mounting holes are in such a way that it will later be easy to zip tie the Arduino down.
Drill through each of these marks with a 1/8" drill bit.
Step 7: More Marking and Drilling
Place the 9V battery on the underside of the cargo bed. Make two marks on each side of the battery and drill them with a 1/8" drill bit.
Step 8: Attach
Plug the 9V clip to the 9V battery and zip tie it to the underside of the RC car.
Trim away the excess bits of zip tie.
Step 9: Shield
Plug the Arduino Motor Shield into the sockets of the Arduino Uno.
Step 10: Attach
Now that the Motor Shield is attached zip tie the Arduino to the back side of the RC Car.
Step 11: Trim
Using scissors or a paper cutter, trim the PC Board until is skinny enough that it slides neatly between the RC car's front grill.
Once made skinnier, shorten it such that it is just long enough to stick out the front.
Step 12: Solder
Solder the PING sensor centered on the front of the trimmed PC Board.
Connect 8" of green wire to the Signal pin, 8" of red wire to the 5V pin, and 8" of black wire to the Ground pin.
Step 13: Insert
Slide the circuit board into the front grill of the car and make sure the sensor is sitting level.
If it is not level, adjust it until it is.
Step 14: Drill and Fasten
Drill an 1/8" hole on each side of the circuit board and firmly secure it to the body of the RC car with zip ties.
Step 15: Extend
Trim away the connector for one of the motors. Connect an 8" red wire to one and an 8" black wire to the other.
Repeat this process with the second motor.
Finally, slide heat shrink tubing over each of the four exposed solder connections and shrink them into place with a heat gun.
Step 16: Clean Up
Zip tie each set of wires together to keep everything tidy.
You may even want to consider zip tying the sets together into a single bundle for the length of wire that passes over the body of the RC car.
Step 17: Put it together
Put the body back onto the frame of the RC car and screw it back into place with the screws you set aside earlier.
Step 18: Program
Program the car with the following Arduino code:
For help getting started with the Arduino, check out the Intro to Arduino Instructable.
Step 19: Wire it up
The ping sensor:
  • Connect the green wire from the Ping sensor to digital pin 7.
  • Connect the black wire from the Ping sensor to ground.
  • Connect the red wire to the power input screw socket on the motor shield.
The front turn motor:
  • Connect the red wire from the front motor to+ port on channel B of the motor shield.
  • Connect the black wire from the front motor to - port on channel B of the motor shield.
The rear drive motor:
  • Connect the red wire from the rear motor to the + port on channel A of the motor shield.
  • Connect the black wire from the rear motor to - port on channel A of the motor shield.
The motor shield:
  • Connect the 5V socket to the power input power screw socket on the motor shield (in addition to the Ping power wire already connected).
  • Connect the ground socket on the shield to the input ground screw socket on the motor shield.
Step 20: Go!
Insert the 9V plug into the power socket on the Arduino to power up your robot.
Note: If you decide that you want to reprogram your Arduino, before you plug in the USB cable, disconnect both the 9V battery and the power connection between the Arduino power socket and the motor shield.
1-40 of 54Next »
mike010101 says: May 9, 2013. 11:54 PM
You mentioned that the front motor was the "turn motor". how exactly does that work? does it actually turn or spins the left or right wheels to achieve turning? I'm wondering if one would need 2 motor controllers for an RC that has for motors
randofo (author) says: May 10, 2013. 9:36 AM
If it has four motors, then you might. Mine has two motors. One drives the back wheels and the front one turns the axle left and right.
angpal59 says: Mar 21, 2013. 7:40 AM
works great but my wheels wont turn, they stay where they are when I fire it up but other than that it works perfect.
angpal59 says: Feb 26, 2013. 1:08 AM
(removed by author or community request)
randofo (author) says: Feb 26, 2013. 12:10 PM
I don't know anything about that shield. I don't know who made it, the pin mapping, or the specs on it.
Unless it is explicitly stated somewhere, never assume any electronics component is interchangeable with any other. I recommend searching the internet for instructions to use exactly what you have.
angpal59 says: Feb 26, 2013. 6:17 PM
but to tell you the truth randofo, it's been so long it could of came from overseas, I'm trying to find out now, I will get back with you sometime
angpal59 says: Feb 25, 2013. 8:49 PM
I am trying to delete one of them but having a hard time, bear with me please
angpal59 says: Feb 25, 2013. 8:37 PM
Here it is, older motor shield, can I use this one?
leeseibert says: Feb 22, 2013. 12:20 PM
Thanks for the How to.
I am working on a project very much like this. See my video here: https://www.youtube.com/watch?v=SPLlTAVeIf8
dzholekbayev says: Feb 11, 2013. 11:06 PM
Good day! I have one question about this project. Should I use Xbee modules to connect PC with robot??? I will be appreciate for your answers!
shar2 says: Jan 15, 2013. 5:44 AM
may I know what's the purpose of connecting the ground socket on the shield to the input ground screw socket on the motor shield?
joedog86 says: Dec 30, 2012. 8:53 AM
Great Instructable! Your build and pictures are so clean! Thank you so much for documenting this so clearly!
The choice of adding a motor shield kind of confuses me, though. If you have a steady hand then connecting four wires to the car's RX chip and taking advantage of the car's already present H-bridge is pretty simple. You can even send PWM signals and it works to control the motor's speed.
If you already have a motor shield or don't want to solder to a surface mount chip then I totally understand, but one can easily cut out $20 to $30 of the cost of this project with some careful soldering.
The.Smart.Man says: Dec 1, 2012. 11:49 AM
dude should you only use new bright cars
hilmara says: Nov 13, 2012. 11:33 AM
Hey there, I used same arduino, same motor shield, same ping sensor, same code, but different rc car, basically the same two simple motors, but somehow my car moves only forward, with a short little stop, than moves again forward even if there are objects, like my hand or foot, It never reverse and doesnt turn the wheels. Can anyone help me? something wrong with the code or ?
shar2 says: Oct 24, 2012. 9:20 AM
Hi, I've used exactly the same kind of Arduino, motor shield, Ping sensor and code but different RC car for my project. However, the rear wheels turn forward and then reverse repeatedly when there is no obstacle. It works fine when there is an obstacle. May I know what's the problem?
focalcity says: Nov 8, 2012. 4:50 PM
hey, I had the same problem. Different car, anytime I power it up. it moves forward then backwards repeatedly, but when I keep my hands in front of it, keeps moving forward
hilmara says: Nov 5, 2012. 3:53 PM
Hi there, cool project. Im planning on doing my own. I got this old r/c car wich only has one motor, the rear one is that okay ? do I have to fix the code? and second, what do I do with the originally on/off button and its wires? thanks in advance !
ataripunkconsole says: Sep 18, 2012. 2:52 PM
hello when i put in the cod e every thing works fine but every 5 second the motors stop and some times the ping sensor does no always work is ths normal
shar2 says: Sep 15, 2012. 9:56 AM
Where did you connect the wires from the battery pack and from the switch to?
randofo (author) says: Sep 15, 2012. 12:00 PM
I am no longer using the car's battery pack and switch. It is all powered off the 9V.
009agent says: Sep 6, 2012. 10:27 AM
How would you go about removing the Arduino so you can use it for other projects. I understand you would need an ATMega chip.
randofo (author) says: Sep 6, 2012. 10:35 AM
ride on toy dude says: Aug 5, 2012. 1:00 PM
randofo (author) says: Sep 4, 2012. 8:16 AM
Not the greatest idea. You can harm the Arduino by doing that, as the motor could produce voltage spikes.
ride on toy dude says: Aug 5, 2012. 1:09 PM
Would it be possible to plug everything straight into the Arduino without the shield?
randofo (author) says: Sep 4, 2012. 8:15 AM
No. You would not be able to change direction and you would be under-powering the motors.
shar2 says: Sep 4, 2012. 6:26 AM
Hi, is it a must that use the Arduino Shield? Will the robot function if only Arduino Uno is used?
randofo (author) says: Sep 4, 2012. 8:13 AM
Yes and no.
ride on toy dude says: Aug 5, 2012. 1:16 PM
Does your car have rack and pinion steering like a car?
ride on toy dude says: Aug 5, 2012. 1:02 PM
I am using a mega x morphinians amphibious rc car. It steers by changing the direction that the wheels spin. How would I code that?
LJduino says: Aug 3, 2012. 8:32 PM
i dont understand how you have the ping (5v) the arduino (5v) and the motors (3-5v) running on a nine volt? can you help me
randofo (author) says: Aug 4, 2012. 8:15 PM
The 9V is going to the Arduino power input jack and being regulated down to 5V. I am using the 5V source from the Arduino to power everything.
AmazingRCstore says: Jul 24, 2012. 1:16 PM
Awesome! very nice!:)
AmazingRCstore says: Jul 24, 2012. 11:42 AM
Wow! that is AMAZING!
emdarcher says: May 29, 2012. 1:28 PM
i just got the car from my local radioshack, but it is so fun that it is hard to get my self to make it into a robot. I think i might make it easier to switch from arduino to RC control somehow. This will be my first arduino robot and robably a light-seeker with a bumper on the front for sensing when it hits walls. do you think that the speed and steering are accurate enough for a robot like the one i want to make? or is a two-wheel and caster style platform better? my apartment has a fabric floor so i don't really know what is best for accurate movement.
emdarcher says: May 29, 2012. 2:13 PM
i just took it apart and it has a smaller PCB than yours and no plugs. i am going to solder wires to the motor connections on the PCB, and then modify the ON/OFF switch to switch between RC or arduino power so i can have the best of both worlds. i can't wait to make my first arduino robot! i hope my setup works.
Jordan arduino says: May 18, 2012. 8:06 PM
Thanks for the Best Instructible
cyclone731 says: May 16, 2012. 6:20 PM
Great instructable! I plan on gettin the parts to make this with my next paycheck. But i've noticed radio shack is out of stock, for the r/c truck, on there site. without a radioshack near by i'm thinking about just purchasing a similar r/c truck. Would i have to rewrite any code or do something different with the shield if i find one with a similar motor setup but diffrent size motors..?
mwaluk says: Apr 29, 2012. 11:21 AM
This is great. I just have one problem where the ping nearly always thinks something is in front of it. This is true even when I reduce the distance to 1 inch. Any ideas of what I did wrong?
martzsam says: May 14, 2012. 7:45 PM
It is possible the ultrasonic sensor is picking up information from another ultrasonic sensor. Do you have any others in use?
How this works:
-Ultrasonic sensors use sound above our hearing range
-when the sound bounces off an object back to the sensor it can judge distance
-if another sensor A is using the same frequency as sensor B, they will both pick up each others feedback
I used to have this problem all the time with the lego mindstorms nxt set when teaching robotics.
1-40 of 54Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
