3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RC Nerf Tank
Step 17Camera voltage regulator
The wireless camera runs off 9V nominally, going any higher will probably fry it. I wanted to hook it up to the main 24V battery so I built this regulator circuit to run it.
Its basically a 9V voltage regulator, a support capacitor, and two diodes. I designed it so that I can hook both the 24V battery up to it as well as the solar backup system. If the 24V battery dies or the robot loses power the camera will automatically switch over to the solar power so I can see where it is.
I added this ultimate paint schematic to show the circuit. Since the power supplies (24v battery and 12v solar) share common ground and are not wired in series you won't ever see 36V. The nature of diodes means only the side with the highest voltage (normally the battery) will pass through. If the 24V drops below 12V (really really dead) or gets shut off somehow then the 12V solar will pass through its diode and the circuit remains powered.
1 comment
Oct 9, 2010. 9:11 AMTbone99 says:
Very nice! I wanted to build this and it's really helped myself and my son do this. I used some other parts from RC Tanks to mod it a bit. If you want to see the pics let me know :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:travis7s
I like to build things... except for wiring.. wiring sucks.
