3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RC Nerf Tank
Step 18Adding a power switch
To turn the tank on and off I'm using a automotive store switch I got for $4. Its rated for 35A so it should be more than enough for what I need. I mounted it on the bottom side panels between the wheels where it hopefully will not get switched off accidentally.
You can also see the grounding stud in the polycarbonate motor mount to tie the negative battery wires together.
1 comment
Aug 29, 2010. 7:06 AMArduino Guy says:
You should add a cover for the power switch: for example you are sneaking up on someone with this robot and the switch catches on something on the floor... what will you do? other than that this thing looks awesome.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:travis7s
I like to build things... except for wiring.. wiring sucks.
