3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
R/C Steam Turbine Tank
Step 10Testing with an air compressor
Now with the gearing finished, it's time to test this puppy out!
Testing steam engines with an air compressor
Here is an useful piece of equipment to test out steam engines. Since steam engines are external combustion engines, you can use an air compressor to test run them, without having to hook up the boiler. This saves a lot of time. You don't have to mount the boiler, rig it all up, waiting for the water to boil, just to debug mechanical issues.
The turbine runs at around 20 -30psi, and this little air brush compressor can simulate the steam. If you use a larger compressor, set it to 20psi for the test. Press the air compressor nozzle into the steam pipe, and blast it with air. Test run the turbine on air, check to make sure that the sprockets and chains are functioning properly, as well as the clutch and steering brakes - you can move the the linkages by hand, before setting up servos.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:crabfu
