Step 11Control Freak
Make sure that the linkages for the clutch and brakes are adjusted to the correct length. The brake pads should not be touching the disc when the servo is in the center position. The Clutch servo should also be centered. You can adjust the length of the servo linkages, and/or the servo horns, to insure that everything lines up.
Add Comment
