Step 15Making the gas tank mount
For this mount, I used sheet metal from the hardware store. This sheet metal is perforated, I have no idea what this was intended for. Cutting sheet metal is pretty easy with a pair of sheet metal shears. Put on some gloves for this step, edges of the sheet metal can be razor sharp after cutting. You can use a piece of paper as a template to make what you want first. But for this mount, it's pretty easy to just cut the sheet metal to shape without a template.
After bending it to shape by hand, paint it with BBQ spray paint. This piece does get pretty hot, since it will be connected to the boiler mount.
I also wanted a skull on the front of the turbine tank. But since I don't have.... say a laser cutter... I had to use a slightly lower tech approach. I cut a thin piece of aluminum with scissors, and couldn't get the fine detail that I wanted, but it turned out ok. I painted it with some spare paint laying around the garage, and then drilled tiny holes to mount it to the perforated sheet metal. I attached it with brads - found at a art/crafts store in the scrapbook section. Of course this is just cosmetic, you can add whatever you like to the tank at this point, or do a complete body work for it. Just make sure that you don't put plastic around high heat areas, or cover up the air supply for the burner etc.
To attach the gas mount, sandwich it between the boiler mount and the sides of the chassis, and reattach with a nuts and bolts.
Add Comment
