3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
R/C Steam Turbine Tank
Step 7Mounting the Steam Turbine
Figuring out how to attach the turbine was fairly straight forward. I was not certain how much gearing I'd need, so I made some space allowances for additional gearing down if needed. First test was a simple mounting the turbine on a piece of scrap wood, and mounting that on the chassis. I tried 1:1 ration from the turbine to the clutch, and tested it with an air compressor (will explain testing with an air compressor in later steps). It needed to be geared down as suspected.
After determining that the is a good placement of the turbine, I proceeded to mount it to the chassis for good.
You need to extend the chassis slightly to make space for the turbine and sprockets. I used [K&S Aluminum sheets for the base, but you can use any sheet metal that is thick enough to be sturdy, but not too heavy. Cut the aluminum to size with a Dremel tool, and drill mounting holes on the mount and the chassis, using some of the original holes. Thread lock to secure the base.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:crabfu
