RC Wheel Traction Hack
Published
Introduction: RC Wheel Traction Hack
Do you have an RC car, but the wheels are PLASTIC! After a while the plastic grips will wear down on the wheel, especially if you are driving it on concrete. Here is a little hack I found to get your RC car speeding down the driveway again!
Step 1:
Got a flat bike laying around? Take the flat tire off your bike and cut it in half long way(like in picture two and three). Once the whole tire is in half, be sure to rub all the powder off the inside of the tire because the glue probably won't stick as well(see the powder on the wheel in pic. four) Now cut the length you need for the size of your tire. Remember we will stretch the rubber a lot, so keep that in mind.
Step 2:
Now take some all purpose super glue and glue about one inch of the end and let it dry for a minute or two (depending on how long your glue takes to dry.
Step 3:
Time for the .......stretch!! Stretch it pretty tight so there is no sag. If you do this right, it the excess may curve around the edge. You can cut any flaps off that might interfere with anything. Make sure when your glue this part that your hold it until it is dry, otherwise it will come undone, because of the tension behind it.
Step 4:
Hope you enjoyed this Instructable! If you have any questions just ask!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    4 Comments
    Good idea. It would be nice if you could cut the tube 2 x through the cross section the width of the tire and stretch around. That way you would not have a seem in the tire. Have you tried that? Maybe the diameter of your wheels are too big to stretch that far.
    Nice hack.....
    How much grip does it have???I mean can u do a drift with it?If you can then it will be a great rally car!
