RC Crawler Scale Aerial
890
4
Posted
Introduction: RC Crawler Scale Aerial
Build your own custom scale aerials for your rc crawlers. scx10, wraith, gmade, ax10 all of them :)
Step 1: You Will Need...
You will need;
Heat shrink (various sizes)
A pen spring
Rod/plastic tube
Nut and bolt
Step 2: Let's Start
Cut the heat shrink about half a cm longer than the spring and slide it into the heat shrink.
Step 3: Add the Tube
Push the tube/rod into the shrink tube and slightly into the spring (from the side that has a bit if extra heat shrink), now heat and shrink.
Step 4: Thicken It Up
I added 2 extra layers to bulk the bottom up a little bit and shrunk it.
Step 5: Prepare the Bolt
Screw the nut most of the way up the bolt.
Step 6: Add the Bolt
Line the bolt up with the bottom and slide some head shrink over the top and shrink it to hold it all together.
Step 7: Finishing Touches
Shrink a little bit of tube over the end to make it look a bit better.
Step 8: Finished
Now you've finished and time to put it on your rig and enjoy the latest accessory! Hope you liked it and please vote for me in the competitions!!!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
