Introduction: RCT3 Mall
Picture of RCT3 Mall
the main formula for How to build a mall using RCT3
Step 1: Adding the Center
Picture of Adding the Center
To start building your mall all you have to do is build a rectangle either 7x5 or 5x3 or even 9x7 path units. I prefer to use 7x5 though.
Step 2: How to Add a Food Court
Picture of How to Add a Food Court
If you wish to add a food court as your coutyard,
1. first you must delete the outer peremeter of the center area
2. next you have to make the center into a checkerboard pattern
3. then you have to add benches all around each path peice
4. then you have to fill the "checkerboard" in
5. finnally you have to add the outer perimeter on again (sorry, I forgot to put a pic for this step)
If you wish to have a fountain for the courtyard, skip this step.
Step 3: Adding a Fountain
Picture of Adding a Fountain
If you wish to have a fountain as your courtyard, (I prefer to use a fountain instead of a food court.)
1. delete the inner area of the center path thing
2. dig a hole in the ground in the area that was deleted
3. fill the hole with water
4. (optional) add a type of fountain in the center of the pool (shown in next step)
Step 4: Adding Floors
Picture of Adding Floors
And next to add the stairs.
1. add stairs in the way shown
2. add path that forms a perimeter directly over the floor's perimeter below
3. (optional) add a third floor (you can have a maximum of only 3 floors (unless your building underground) because the game does not allow you to place the stalls any higher)
If you want to only have a single floor in your mall, then skip this step and add your stalls & walls. I will make another instructable on how to build a single floor/ underground RCT3 mall.
Step 5: Adding Stalls
Picture of Adding Stalls
First you just have to build a bathroom on each floor on one side of the stairs and then just build one of the other three neccesities(ATM, First Aid, Information.) on the other side of the stairs
Finnally comes the time where you get to add the stalls.
The stalls that don't fit can go on the top floor. (you'll see what I mean once you start adding the stalls.) If the stalls won't fill the entire mall, you can just build more than one of some stalls.
Step 6: Adding Walls
Picture of Adding Walls
Now all you have left to do is build the walls. Oh and I almost forgot...
1. make a path underneath the stairs that is 3x3 path units, you can also make the mall floor concrete, 'cause you don't see grass growing inside a mall that often
2. add walls around the shops and the stairs/ path; for 1 floor high make it 3 full hieght walls high; for 2 floors, 5; and for 3 floors, 7.
3. after that, add an outer wall that is spaced from the inner wall by 1 unit, except for on the front side. the mall should now be 11x10. Next you have to put the big window at the front of the mall like so. Finally it is time for the roof, so just add the roof on top. you can also add a skylight directly over the pool/ food court if you wish.
Custumise your mall all you want, from a balcony to a hundred stories to an indoor roller coaster. You can try to apply a similar concept when building huge indoor parks like the one i'm working on: http://www.youtube.com/watch?v=Jga0_FqVqpw
kgauuan (author)2013-02-14
please please please tell me how did you add stalls on the paths?
Lowney (author)2009-09-02
I like the other building opposite the mall! Out of interest what is the most exciting coaster you've ever made? My record is "Excitement Rating: 10.35 (extreme)"
knexfreakbuilder (author)Lowney2010-10-19
my record is 30-31(Ultra extreme!)
Lowney (author)knexfreakbuilder2010-10-20
PICTURES NAO!
coolknexcreations (author)Lowney2009-09-02
12.56
Lowney (author)coolknexcreations2009-09-27
Woa as your excitement rating? My record now is 12.22 (look above)
coolknexcreations (author)Lowney2009-09-28
Yea, mine is a giga coaster...
Lowney (author)coolknexcreations2009-09-28
Looks like I got someone to beat!
coolknexcreations (author)Lowney2009-09-30
u probably will, LOL it was pure luck
erisom13 (author)2010-03-02
how do you add the stalls to the path's?
finmonster (author)2010-01-22
so what i have an 800ft high coaster which goes 150mph
Tornado96 (author)2009-12-11
I once made a mall that had a roller coaster going through it. : )
Lowney (author)2009-09-27
Y'know I said about my 10.35 exciting coaster? Well I broke my record with a 12.22 extreme excitment coaster!
Lowney (author)2009-09-04
lol, but "Uber-Extreme" is the highest!
Lowney (author)2009-09-03
Have you got any proof? (Like screenshot it with F10)
then (author)2008-04-24
if the loor is 5x3, the outside should be 9x8
BostenFlyers5 (author)then2009-05-02
No it should be 7x5 because the 5 becomes the 3 and the 7 becomes the 5.
brian chin (author)2008-09-21
Hello,everybody,I come from Hong Kong.I want to play RCT3 very much,so can you teach me how to get RCT3.If you have RCT3,please send me thx~ E-mail: money19930615@yahoo.com.hk
Owenmon (author)brian chin2009-02-09
ebay?
then (author)Owenmon2009-02-14
there's also the illegal way... which I don't use... just a little, you know, suggestion... If you don't mind the fbi coming to your house... *cough*...
Owenmon (author)then2009-02-15
LOL
watermelonhead (author)2008-10-26
how do you get the veiw of the peeps? i forgot. :D
then (author)watermelonhead2008-11-28
Change their name to Johnny Watts and you'll get a coastercam view through the eyes of the peep
Sturmgewehr44 (author)2008-08-15
nice job, but i cant figure out how to place the stalls
Shrimp782 (author)2008-07-25
Ok ppl, if you have Roller coaster tycoon 3 then you should know what RCT3 means! Of you dont know what it means and dont have it then why even look at this?
then (author)2008-05-17
then (author)2008-04-29
Mall building downloadgo to that link for the file download, it requires only the regular RCT3 and the building is made for a 7x5, 3 story mall.
matchlighter (author)then2008-04-29
thx
SeMi_AuToMaTic (author)2008-04-29
dude this is awesome i am doing it right know!!!!!!!
Well if you're reading this instructable you should probably have RCT3, it's just short for Roller Coaster Tycoon 3 becase it doesn't take as long to spell the name.
BTW this is the only instructable on here for RCT3, and it is the only tutorial on the internet on the main formula of building malls using RCT3.
Got it?
XD
Mister_Caipirinha (author)then2008-04-25
I don't have RCT3 and I looked at your Instructable to see what your Instructable was about. I thought you were building a maul but had misspelled maul. When I saw the pictures, I then thought it was from a Civilization or SIMS or some other simulator. I'm thankful someone asked what RCT3 stood for. It's not a stretch to think that other people don't know as much about your own area of interest as you do. Thanks, it looks neat!
then (author)Mister_Caipirinha2008-04-27
it is REALLY neat!
S1L3N7 SWAT (author)2008-04-24
Yeah, what the heck is RTC3?
JakeTobak (author)2008-04-24
Should change the title to spell out the full name of the game. I shouldn't have to Google "RTC3" to know what you're talking about.
About This Instructable
11,632views
6favorites
License:
More by then:Nemo: MY first Ball MachineHow to clean golf clubsRCT3 mall
Add instructable to:
