HOW THIS THING WORKS:
The module has 3 pairs of wires.
1- imput
2- output
3- phone plug
1-(2 long wires at the bottom) imput is you battery pack. You need a minimum of 5 volts.
2-(2 short wires next to the LED) the output is where you plug the fuse. It always leaks 1.45volts until the whole thing is activated - it is activated by part 3
3-(black plug imput) phone plug, this is where the cellphone is pluged (you will see how this is done in later steps). When the phone rings, it will open up a passage for ALL of the voltage to go from 1(imput) to 2(output) WITHOUT touching 3(cell phone); this means you will NOT fry the phone as no electricity goes in there.
Summary: when you call your phone connected to this, it will activate what is pluged on the output (be it a model rocket fuse, or a more powerful latching 2$ relay that controls a 120v device).
Remove these ads by
Signing UpStep 1Here is the basic schematic and the parts you will need.
-555 IC timer (on which pin 1 is identified, I use a TA7555P chip)
-resistors : 33kohm, 467ohm, 1kohm
-Capacitors: 0.1uf and 0.01uf
-a plug that will fit the wire you will put in your phone, a cellphone and the cable that fits in the plug you used.
Optional: (it is a testing mechanism to see if your circuit works when the phone is rigning)
- 1 pushbutton or switch
- 1 LED; the positive (longer leg) is the top 5 on the schematic
The 555 timer IC chip used here WILL heat when the cellphone rings so do not touch it but it should not be damaged. If it is, swap it (its why I put mine in a IC socket, for 80 cents, id rather throw it out and swap it in case of problems rather then starting from scratch again.) This chip was not made for this, its why you will never find this circuit anywhere else (for now :p)
http://www.redcircuits.com/Page47.htm
These work because your cell phone emits a signal just before it rings, and these simple circuits detect that signal and trigger. It needs to be placed very close to your phone, but does not require you to modify your phone at all.
My flashing cradle, unfortunately doesn't work with Verizon, which is my carrier, but it works with my brother's sprint/pcs phone.
It actually wouldn't be too hard to build - using a microcontroller to A2D the 'output' cellphone's speaker and calculating the frequency, implementing a call auto-accepter (easy with a microcontroller), and building a bank of output transistors to sit between microcontroller and detonators. This would allow for the control of an arbitrary number of fireworks; the only limiting factor is call quality, which impacts how accurately frequencies can be matched.
Does anyone know of a super cheap prepaid phone service? I can't just go out and buy a junky SIM phone; Verizon doesn't use SIM cards :(
ps. this was made because I like making stuff and was used once (at a very safe distance) for my scout troupe.
Although you've stated an example of what you used it for, that's akin to saying you used a rifle's stock to dig a hole; the main purpose of a rifle is to shoot, the main purpose of this device will be to detonate an explosive charge, which is precisely what you built it to do; the only issue is that the chances of someone utilizing this on the 4th of July for their fountains, as opposed to IEDs, are slim to none.
P.S. The title has a misspelled word in it...'fierwork'. That in itself might lead one to believe this is an 'ible of suspect origins.
ps. thanks, I had not noticed that!
It 1- has no voltage leakage,
2- can be used with any voltage,
3- takes NO expertise or skills and finally
4- it only needs a battery 2 wires and the phone, nothing else (well maybe a bit of tape).
I am tired of being apologetic about this project, it is what it is... if you really want to blow stuff up, this is not the simplest way, this is useful for someone who wants a reusable DIY project. If you want a single use, there are waaaaaaaaaaaaay easier ways and if you want a easy reusable non-diy relay, you can buy relays online for about 50 to 200$ (depending on what precision you want), ready made that have much better voltage control)
It really depends on how you wan't to use it.
For most people the 555 is their first IC cuz it's so versatile, easy to use and just plain awesome. You can find many comprehensive schematics online.
Oh and I was confused about something, when you say "imput", do you mean "input" ? Overall, great concept. With a little black powder you could remotely scare the crap out of someone. lol
