3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RF Serial Data Link {through USB}
TECGRAF DOC
How to transmit data using a cheap RF module through USB. The circuit receives energy from the USB port (may provide 100mA and with some programming you can reach 500mA)
List of Materials:
1 - One pair of RF module (like Laipac RLP/TLP433A) look after it in sparkfun.com (they have different operating frequencies: 315, 433 and 917(?) MHz)
1 - TSUB3410 - Serial-to-USB integrated chip (QFP-32) from Texas Instruments.
1 - One Power LED (you may skip it)
1 - 3.3V LDO (Low Drop-out) regulator - to connect in the +5V (+/- 10%) line from the USB.
Start with the "walkthrough.pdf" guide, after it we will improve the wireless link to be connected to an USB port.
! ! ! - Altought it may look like a very simple circuit (just the RF link), you may find some rocks in your pathway.
I still don't know if this is a reliable circuit..so be carefull where you are going to use it. Be advised to try this circuit ONLY when you are in a good mood! if not go play PS2...otherwise this can damage your parasympathetic nervous system!
Step 1Checking RF Modules
Checking RF Modules
First of all you must go exactly through the steps written in the PDF file attached to this site ("walkthrough...")
Itīs a good idea to check first the modules. Do it on a breadboard, it works? Fine, move to the next step... or check connections, wires, supply (did you turn it on?).
You can check the wireless link with an osciloscope or using any (hyper) terminal software. Check the maximum baud rate! (mine 4800bps). You may need a MAX232 chip, it is a Serial level converter...
[ PC >> MAX232 >> TX ] ~~~~~~~ air ~~~~~~~~ [ RX >> MAX232 >> PC ]
email me...may be I can help you!
11 comments
Dec 1, 2011. 5:50 AMajayvasani41 says:
hi friend
i am Ajay. i want to make 8 channel RF receiver and transmitter. i men i want to
operate 8 dc motor revers and forward throat RF remote control ..using my engineering project then how can i make.. give me some instruction..pls
Oct 31, 2011. 2:41 AMamison says:
How do I connect from PC->RS232->RS232TOTTL->RF Modules?
The RS232TOTTL has rx ,dx pins, but the RF Module just has 1 Data pin?
Oct 1, 2009. 3:02 AMvergiliszta says:
Hi! How to download firmware to the TUSB3410?
May 8, 2007. 10:23 AMdarling says:
hello if somebody knows like handling to modules RF tlp433a and if somebody has handled some vos modules that trasmitan. thanks
Aug 24, 2007. 1:41 PMthemischiev says:
Hey Barmak, there is a way to use this device to connect a webcam and make a "wireless webcam"
Jul 27, 2006. 10:00 AMofflogic says:
Kick-ass Instructable on the Laipac-USB wireless. The last page throws an error( “ERROR 403: can not view: E9XCJPBXSCEPYPFGNC”), probably a their-problem, not a your-problem. I’ve done a 916MHz wireless dingus for monitoring a piece of mobile equipment using the RFM TX6xxx series parts(www.rfm.com). Wayyy smaller than the Laipac, and sealed. You can get 1Mb/sec both ways with the TR1100. It rocks, seriously. Great to see your work, just had to drop you a line. Bravo.
Jul 23, 2006. 11:39 AMMurf says:
Hey, whats your e-mail barmak??? I wanted to ask you a few specific questions
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:barmak
