3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RF probe
RF probe
Probe for measuring in the Radio Frequency range built inside an earphone jack, designed to have minimum capacitance and complete shielding.
Step 1The parts
The parts
You will need:
A diode. Germanium point contact, OA79 or 1N34 is the preferred and traditional choice. But a modern substitute will be a schottky (gold bonded) diode. These have a low forward voltage, below 250 millivolts or so, versus the 600 or so of the silicon diode.
A few capacitors, chip type, value not critical, around 1 nf to 100 nf. (or 1000 pf to 0.1 microfarad)
One resistor, 1 Megohm.
One stereo earphone jack.
One pin from a turned pin IC socket. This forms the 'hot' end of the probe, so that various pins can be inserted for probing. A short piece from a needle for exploratory work. A piece of wire soldered to the circuit board when using it for a tuning up session, requiring it to be in place for a long time.
The circuit is traditional, as below:
   C1          R<--||-------/\/\/\/\-------------o +      |                |     ---               |      ^                |     /-\ diode        === C2      |                |      |                |<--------------------------------o -
19 comments
Dec 5, 2010. 8:37 PMJimmy Proton says:
i never knew what those clear things with the colors on them are until now, why do i only see them on tvs and monitors?
Jul 17, 2011. 6:53 PMS33PlusPlus says:
What kinds of things do you take apart? I find so many signal diodes (1N4148's typically) in trashed electronics I don't bother desoldering them anymore. (Besides, they're cheap enough that using a new one in a project is less troublesome than using a damaged scrap bin diode.)
Jul 17, 2011. 10:46 PMJimmy Proton says:
I take apart everything that i can get my hands on. =)
Jul 19, 2011. 12:44 PMS33PlusPlus says:
Me too :3
I prefer early 90's or late 80's era devices, before everything went surface mount.
If you take recent products apart, you'll be quite disappointed at the component yield. You've probably seen few discrete signal diodes because manufacturers cram everything they can into ICs to reduce component counts.
On the other hand, an early 90's handheld four-in-a-row style game I recently took apart (lack of backwards current protection fried a LED ) has 34 discrete transistors in it!
Try going through free piles after garage sales or the free section on your local craigslist boards.
Jul 20, 2011. 9:07 PMJimmy Proton says:
Old CRT TV's probably have the best stuff in them. Whenever I take apart new things I put the boards in the toaster oven or i destroy them.
Jan 6, 2011. 1:08 PMtaterkiller says:
will this work as an antenna
Feb 9, 2007. 5:42 AMPetervG says:
I thought the first picture was a person trying to pull their bike away from a huge cylindrical crusher..
Feb 9, 2007. 5:38 PMdcshoeco33 says:
lol i seriously rofl'd it does look like that
Jun 30, 2008. 8:07 PMchrisayad says:
lolool
Jun 30, 2008. 9:40 PMPetervG says:
Wait, how does it look like that. I wish I knew what I meant.
Feb 18, 2007. 1:51 AMPunkguyta says:
Oh wow, this does look good. Is it as fragile as it looks?
Feb 19, 2007. 2:23 AMPunkguyta says:
I think that epoxy would be best, hot glue expands, and you tend to get a but too much, super glue is runny and I always get it on my fingers (my tongue too once, don't ask).
Feb 11, 2007. 12:33 AMcylver says:
Okay, for those of you who want a more in-depth understanding of how it works... c1 is a dc-blocking capacitor. It's there to make sure you're only measuring the AC voltage in the circuit. d1 is there to convert the ac into dc pulses. c2 is a filtering capacitor, so that you're reading the peak voltage (or close to it) rather than the average, which will be quite a bit lower. It also allows any remaining ac a nice path to ground. R makes sure that you don't draw too much current through your meter, destroying it. One thing to keep in mind is that you'll probably want a shielded cable, to keep from picking up stray AC from the board you're testing. RG 174 coax would be nice if you've got some. Connect the shield to the - side of the circuit, and the center conductor to the + side. Slap a BNC connector on the end, rather than a phone plug, and you can use the probe with an oscilloscope, too.
Feb 10, 2007. 10:44 AMDonTron says:
This is a classic from the AARL. The neatest ones were built, IMHO, out of lipstick tubes. The non-linearity of the diode, not to mention the integrator, limits the accuracy of this technique, so nowadays, something built out of today's high-speed op-amps might be possible. A bolometer would be more complex, and slower, but far more accurate. This is a very useful instrument, where it is indicated. "Rectify and integrate" is also the principal behind simple AM detection, although with a shorter time-constant, typically.
Feb 9, 2007. 4:48 PMadmanrocks says:
this may be a stupid question. but i dont know what it does. so what does it do?
Feb 9, 2007. 7:34 PMsysadmn says:
Most voltmeters don't accurately measure AC (alternating current) at high frequencies (RF = Radio Frequency). At RF frequencies, the components in the probe convert the AC value to an equivalent DC value that a voltmeter can accurately measure. There is a good writeup here ( http://www.io.com/~n5fc/rfprobe1.htm )
Feb 10, 2007. 9:42 AMadmanrocks says:
ok, cool
Feb 9, 2007. 12:19 PMrobonut625 says:
Nice instructable, neelandan.... one of those pieces of test equipment you don't think you need until you have one!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:neelandan
Employed as an Engineer in Electronics. Interested in building small circuits around tiny chips (the electronic kind).
