Introduction: RFID CARD READER WITH ARDUINO,RFID-RC522 and LCD 16x2
Radio-frequency identification (RFID) uses electromagnetic fields to automatically identify and track tags attached to objects. The tags contain electronically stored information. Passive tags collect energy from a nearby RFID reader's interrogating radio waves. Active tags have a local power source such as a battery and may operate at hundreds of meters from the RFID reader. Unlike a barcode, the tag need not be within the line of sight of the reader, so it may be embedded in the tracked object. RFID is one method for Automatic Identification and Data Capture (AIDC).
RFID tags are used in many industries, for example, an RFID tag attached to an automobile during production can be used to track its progress through the assembly line; RFID-tagged pharmaceuticals can be tracked through warehouses; and implanting RFID microchips in livestock and pets allows positive identification of animals.
Since RFID tags can be attached to cash, clothing, and possessions, or implanted in animals and people, the possibility of reading personally-linked information without consent has raised serious privacy concerns. These concerns resulted in standard specifications development addressing privacy and security issues. ISO/IEC 18000 and ISO/IEC 29167 use on-chip cryptography methods for un-traceability, tag and reader authentication, and over-the-air privacy. ISO/IEC 20248 specifies a digital signature data structure for RFID and barcodes providing data, source and read method authenticity. This work is done within ISO/IEC JTC 1/SC 31 Automatic identification and data capture techniques.
ARDUINO UNO: The Uno is a microcontroller board based on the ATmega328P. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz quartz crystal, a USB connection, a power jack, an ICSP header and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. You can tinker with your UNO without worrying too much about doing something wrong, worst case scenario you can replace the chip for a few dollars and start over again.
"Uno" means one in Italian and was chosen to mark the release of Arduino Software (IDE) 1.0. The Uno board and version 1.0 of Arduino Software (IDE) were the reference versions of Arduino, now evolved to newer releases. The Uno board is the first in a series of USB Arduino boards, and the reference model for the Arduino platform; for an extensive list of current, past or outdated boards see the Arduino index of boards.
LCD 16 x 2: LCD (Liquid Crystal Display) screen is an electronic display module and find a wide range of applications. A 16x2 LCD display is very basic module and is very commonly used in various devices and circuits. These modules are preferred over seven segments and other multi segment LEDs. The reasons being: LCDs are economical; easily programmable; have no limitation of displaying special & even custom characters (unlike in seven segments), animations and so on.
A 16x2 LCD means it can display 16 characters per line and there are 2 such lines. In this LCD each character is displayed in 5x7 pixel matrix. This LCD has two registers, namely, Command and Data.
The command register stores the command instructions given to the LCD. A command is an instruction given to LCD to do a predefined task like initializing it, clearing its screen, setting the cursor position, controlling display etc. The data register stores the data to be displayed on the LCD. The data is the ASCII value of the character to be displayed on the LCD. Click to learn more about internal structure of a LCD.
RFID- RC522: There are cheap RFID modules that can read and write Mifare's tags and being sold at several web stores, like eBay and included with many "starter kits" nowadays. Simply search RFID-RC522 (MF-RC522). The microcontroller and card reader uses SPI for communication (chip supports I2C and UART protocols but not implemented on library) (Maybe someone implements?). The card reader and the tags communicate using a 13.56MHz electromagnetic field. (ISO 14443A standard tags)
Step 1: COMPONENTS:
- RFID RC-522
- ARDUINO UNO
- LED
- BUZZER
- JUMPPER WIRES
- BATTERY (9V WITH CAP)
- PLUG (5 x 2.1)
- LCD (16 x 2)
- ADDITIONAL CONNECTION PINS
- RISISTANCE (220 ohm) (x 2)
- VARIABLE RESISTOR (10 K)
Step 2: CIRCUIT DIAGRAM:
Step 3: CODE:
RFID CARD READER By nonstopengineering Using Arduino,RFID-RC522 and LCD 16x2 ------------------------------------------*/
#include <eeprom.h> //Library To read and write PICC's UIDs from/to EEPROM #include <spi.h> //Library RC522 Module uses SPI protocol #include <mfrc522.h> //Library RC522 Module #include <liquidcrystal.h> //Library for LCD Display</liquidcrystal.h></mfrc522.h></spi.h></eeprom.h>
boolean match = false; // initialize card match to false boolean programMode = false; // initialize programming mode to false int successRead; // Variable integer to keep if we have Successful Read from Reader byte storedCard[4]; // Stores an ID read from EEPROM byte readCard[4]; // Stores scanned ID read from RFID Module byte masterCard[4]; // Stores master card's ID read from EEPROM #define SS_PIN 10 #define RST_PIN 9 MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance. LiquidCrystal lcd(7, 6, 5, 4, 3, 2); //Initializing LCD PINS as (RS,EN,D4,D5,D6,D7) void setup() { // put your setup code here, to run once: Serial.begin(9600); // Initialize serial communications with PC lcd.begin(16, 2); //Initializing LCD 16x2 pinMode(8, OUTPUT); //LED and Buzzer PIN OUT SPI.begin(); // MFRC522 Hardware uses SPI protocol mfrc522.PCD_Init(); // Initialize MFRC522 Hardware mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max); if (EEPROM.read(1) != 1) { // Look EEPROM if Master Card defined, EEPROM address 1 holds if defined Serial.println("No Master Card Defined"); //When no Master Card in Your EEROM (Serial Display) Serial.println("Scan A PICC to Define as Master Card"); lcd.clear(); lcd.setCursor(0, 0); lcd.println("SET MASTERCARD "); //When no Master Card in Your EEROM (LCD Display) lcd.setCursor(0, 1); lcd.println("SCAN A PICC....."); //Scan any RFID CARD to set Your Master Card in Your EEROM (LCD Display) delay(1500); do { successRead = getID(); // sets successRead to 1 when we get read from reader otherwise 0 } while (!successRead); //the program will not go further while you not get a successful read for ( int j = 0; j < 4; j++ ) { // Loop 4 times EEPROM.write( 2 + j, readCard[j] ); // Write scanned PICC's UID to EEPROM, start from address 3 } EEPROM.write(1, 1); //Write to EEPROM we defined Master Card. Serial.println("Master Card Defined"); } Serial.println("Master Card's UID"); for ( int i = 0; i < 4; i++ ) { // Read Master Card's UID from EEPROM masterCard[i] = EEPROM.read(2 + i); // Write it to masterCard Serial.print(masterCard[i], HEX); //Master Card only view in serial Serial.println("Waiting PICCs to bo scanned :)"); } //WAITING TO SCAN THE RFID CARDS: Serial.println(""); Serial.println("Waiting PICCs to bo scanned :)"); lcd.clear(); lcd.setCursor(0, 0); lcd.println("WAITING "); lcd.setCursor(0, 1); lcd.println("FOR PICC.... "); delay(1500); } void loop() { lcd.clear(); lcd.setCursor(0, 0); lcd.print(" SWIPE"); lcd.setCursor(0, 1); lcd.print(" YOUR CARD");
/* if (digitalRead(BUTTON) == HIGH); //To Delete the EEROM USE the below command just run it { // for (int i = 0 ; i < EEPROM.length() ; i++) { // EEPROM.write(i, 0); // } // } */ do { successRead = getID(); // sets successRead to 1 when we get read from reader otherwise 0 if (programMode) { // Program Mode cycles through RGB waiting to read a new card } else { }} while (!successRead); //the program will not go further while you not get a successful read if (programMode) { if ( isMaster(readCard) ) { //If master card scanned again exit program mode Serial.println("This is Master Card"); Serial.println("Exiting Program Mode"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("EXITING FROM"); lcd.setCursor(0, 1); lcd.print("MASTERCARD MODE"); delay(2000); programMode = false; return; } else { if ( findID(readCard) ) { //If scanned card is known delete it Serial.println("I know this PICC, so removing"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("AVAILABLE!"); lcd.setCursor(0, 1); lcd.print("SO DELETING....."); delay(5000); deleteID(readCard); Serial.println("-----------------------------"); } else { // If scanned card is not known add it Serial.println("I do not know this PICC, adding..."); lcd.clear(); lcd.setCursor(0, 0); lcd.print("Card no:"); lcd.setCursor(0, 1); lcd.print(readCard[0], HEX); lcd.print(readCard[1], HEX); lcd.print(readCard[2], HEX); lcd.print(readCard[3], HEX); lcd.print(readCard[4], HEX); delay(4000); lcd.clear(); lcd.setCursor(0, 0); lcd.print("NOT AVAILABLE"); lcd.setCursor(0, 1); lcd.print("SO ADDING......."); delay(5000); writeID(readCard); Serial.println("-----------------------------"); }} } else { if ( isMaster(readCard) ) { // If scanned card's ID matches Master Card's ID enter program mode programMode = true; Serial.println("Welcome to Mastercard Mode"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("WELCOME TO"); lcd.setCursor(0, 1); lcd.print("MASTERCARD MODE"); delay(3000); int count = EEPROM.read(0); // Read the first Byte of EEPROM that Serial.print("I have "); // stores the number of ID's in EEPROM Serial.print(count); Serial.print(" record(s) on EEPROM"); Serial.println(""); Serial.println("Scan a PICC to ADD or REMOVE"); Serial.println("-----------------------------"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("SCAN PICC TO"); lcd.setCursor(0, 1); lcd.print("ADD OR REMOVE..."); delay(2500); } else { if ( findID(readCard) ) { // If not, see if the card is in the EEPROM Serial.println("Acces Granted"); lcd.clear(); lcd.setCursor(0, 0); lcd.print(" CONGRATULATION"); lcd.setCursor(0, 1); lcd.print(" ACCESS GRANTED"); digitalWrite(8, HIGH); delay(1500); digitalWrite(8, LOW); lcd.clear(); } else { // If not, show that the ID was not valid Serial.println("Access Denied"); for (int abcd = 0; abcd < 6; abcd++) { lcd.clear(); lcd.setCursor(0, 0); lcd.print(" SORRY"); lcd.setCursor(0, 1); lcd.print(" ACCESS DENIED"); digitalWrite(8, HIGH); delay(700); digitalWrite(8, LOW); lcd.clear(); lcd.print(" YOU'RE NOT "); lcd.setCursor(0, 1); lcd.print(" AUTHORIZED "); delay(700); } lcd.clear(); }}}} int getID() { // Getting ready for Reading PICCs if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue return 0; } if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue return 0; } // There are Mifare PICCs which have 4 byte or 7 byte UID care if you use 7 byte PICC // I think we should assume every PICC as they have 4 byte UID // Until we support 7 byte PICCs
Serial.println("Scanning PICC's UID........."); lcd.clear(); lcd.setCursor(0, 0); lcd.print("SCANNING"); lcd.setCursor(0, 1); lcd.print("PICC's UID....."); delay(2000); for (int i = 0; i < 4; i++) { // readCard[i] = mfrc522.uid.uidByte[i]; Serial.print(readCard[i], HEX); } Serial.println(""); mfrc522.PICC_HaltA(); // Stop reading return 1; } boolean isMaster( byte test[] ) { if ( checkTwo( test, masterCard ) ) return true; else return false; }
boolean checkTwo ( byte a[], byte b[] ) { if ( a[0] != NULL ) // Make sure there is something in the array first match = true; // Assume they match at first for ( int k = 0; k < 4; k++ ) { // Loop 4 times if ( a[k] != b[k] ) // IF a != b then set match = false, one fails, all fail match = false; } if ( match ) { // Check to see if if match is still true return true; // Return true } else { return false; // Return false }} boolean findID( byte find[] ) { int count = EEPROM.read(0); // Read the first Byte of EEPROM that for ( int i = 1; i <= count; i++ ) { // Loop once for each EEPROM entry readID(i); // Read an ID from EEPROM, it is stored in storedCard[4] if ( checkTwo( find, storedCard ) ) { // Check to see if the storedCard read from EEPROM return true; break; // Stop looking we found it } else { // If not, return false }} return false; } void readID( int number ) { int start = (number * 4 ) + 2; // Figure out starting position for ( int i = 0; i < 4; i++ ) { // Loop 4 times to get the 4 Bytes storedCard[i] = EEPROM.read(start + i); // Assign values read from EEPROM to array } } void deleteID( byte a[] ) { if ( !findID( a ) ) { // Before we delete from the EEPROM, check to see if we have this card! failedWrite(); // If not } else { int num = EEPROM.read(0); // Get the numer of used spaces, position 0 stores the number of ID cards int slot; // Figure out the slot number of the card int start;// = ( num * 4 ) + 6; // Figure out where the next slot starts int looping; // The number of times the loop repeats int j; int count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards slot = findIDSLOT( a ); //Figure out the slot number of the card to delete start = (slot * 4) + 2; looping = ((num - slot) * 4); num--; // Decrement the counter by one EEPROM.write( 0, num ); // Write the new count to the counter for ( j = 0; j < looping; j++ ) { // Loop the card shift times EEPROM.write( start + j, EEPROM.read(start + 4 + j)); // Shift the array values to 4 places earlier in the EEPROM } for ( int k = 0; k < 4; k++ ) { //Shifting loop EEPROM.write( start + j + k, 0); } successDelete(); }} //For Failed to add the card: void failedWrite() {
Serial.println("something wrong with Card"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("SOMETHING WRONG"); lcd.setCursor(0, 1); lcd.print("WITH CARD"); delay(2000); } //For Sucessfully Deleted: void successDelete() { Serial.println("Succesfully removed"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("SUCCESFULLY"); lcd.setCursor(0, 1); lcd.print("REMOVED"); delay(2000); } int findIDSLOT( byte find[] ) { int count = EEPROM.read(0); // Read the first Byte of EEPROM that for ( int i = 1; i <= count; i++ ) { // Loop once for each EEPROM entry readID(i); // Read an ID from EEPROM, it is stored in storedCard[4] if ( checkTwo( find, storedCard ) ) { // Check to see if the storedCard read from EEPROM // is the same as the find[] ID card passed return i; // The slot number of the card break; // Stop looking we found it } } } //For Sucessfully Added: void successWrite() {
Serial.println("Succesfully added"); lcd.clear(); lcd.setCursor(0, 0); lcd.print("SUCCESFULLY"); lcd.setCursor(0, 1); lcd.print("ADDED"); delay(2000); } //For Adding card to EEROM: void writeID( byte a[] ) { if ( !findID( a ) ) { // Before we write to the EEPROM, check to see if we have seen this card before! int num = EEPROM.read(0); // Get the numer of used spaces, position 0 stores the number of ID cards int start = ( num * 4 ) + 6; // Figure out where the next slot starts num++; // Increment the counter by one EEPROM.write( 0, num ); // Write the new count to the counter for ( int j = 0; j < 4; j++ ) { // Loop 4 times EEPROM.write( start + j, a[j] ); // Write the array values to EEPROM in the right position } successWrite(); } else { failedWrite(); } }
Step 4: ARDUINO CODE FILE:
Step 5: DESIGNED CIRCUT:
Step 6: FINAL DESIGN:
Step 7: WORKING:
First Time Authors Contest 2016
Arduino Contest 2016
