iImage Information
If anyone has and RFID key that is required to start a car and has tried to get a copy we know it runs over a $100 to get one, and most stores will not just make a non-RFID copy due to legal issues. But if you need one that will just unlock the doors to get the accidentally locked set of keys out, this instructable will show you how to make a real copy of the key from a blank key you can purchase at the store.
Step 1What you will need:
iImage Information
First you will need some common and uncommon materials.
A blank key that has the same V grooves as the real one. For the most part if they will not duplicate it they should sell you the blank, Lowes sold me one for $1.97 (the total cost of this project)
A filing set with different types if files (mainly a round, and a D shaped file)
Non-hardening clay that is not reactive to heat
A grinding wheel or dremel tool to help speed up the process
A vice (optional)
A lead melting pot with Lead or a soldering iron
tape
Some side cutter snips
http://electronics.howstuffworks.com/gadgets/automotive/rfid-ignition-system.htm
Of course that meant that I had to try a dumb key in my wife's Grand Caravan (I forgot to ask her permission first, OOPS!). It ran for about 5 seconds and quit. The little red security dot on the instrument panel flashed angrily. After inserting my smart key, it started right up and drove the same as before.
I can't say if that's the case for every other car, but it suits my needs for now.
I can see that an ECU could go into non-responsive mode that requires the aforementioned "buzz box" to revive, and even that seems unlikely to me. It seems more likely that the ECU would just be unresponsive for an extended period of time.
As you said, though - it is likely that this varies from manufacturer to manufacturer.
To put a Ford into program mode, you put a working/recognized key in the ignition, and turn it on and off rapidly (something like seven times). The car computer responds by cycling the electric locks - if so equipped - to show that it is in programming mode. You then put the new key in and turn it on (I think), or maybe start the car, within something like 15 seconds.
I don't doubt that some cars go into some sort of failure mode if you try to start them with some sort of unauthorized key. I wonder if that would survive disconnecting the battery, or clearing with a code reader? I know that on a Ford, having too many keys and whatnot on the same key ring can block the RF signal, preventing the car from starting. I'm pretty sure this has happened three times in a row, with no ill effects.
The process to get the car to recognize another remote is similar, except you press any key on the new remote.
Since the RFID remote key blanks are so blooming expensive, I have considered using trying to reuse a key that I have left over for a different Ford vehicle that I no longer own. I wonder how hard it would be to attach a new key to the old RFID part?
As for the utility of posting an instructable on how to do all this, I think one can say that quite a number of the instructables posted on this site - perhaps a majority - are for things that are available commercially, frequently for less than what the DIY materials cost, let alone labor. So who cares?
According to my owner's manual you need to valid keys. Place one in ignition turn on and off several times (can't remember how many) remove and do the same with the other valid key. You then have 10 seconds to put the new key in ignition and turn on.
IF YOU PUT THE NEW, UNPROGRAMMED KEY IN THE IGNITION WITHOUT FOLLOWING THESE INSTRUCTIONS IT WILL BE FRIED AND CAN NOT BE PROGRAMMED !!!
If you don't have two keys you have to go to ACE for the $69 key or Ford will charge you $100 to program your key. If you lose all your keys the vehicle needs to be towed to the dealer for a new key. Sounds like having an extra was cheap insurance. I will never let myself be reduced to one key. Also the ignition is set to only program 8 keys so don't lose them all the time.
I just don't see how the key could possibly be "fried" by putting it in the ignition. More likely that the code is put on a sort of "black list" that it won't allow to be programmed in the ECU.
There's a difference between "valid" keys and "programmed" keys. Ace doesn't program your key for you, they cut a key that has the RFID chip in it that your car's ECU will recognize. You get the ECU to recognize the key, using the process you outline.
It's easy to tell in a vehicle with electric door locks how many times to turn the ignition on and off, as the ECU puts the locks up and down to acknowledge that it's ready to be programmed.
What we teach apprentices is to find the datum point of the key (shoulder or tip-aligned) and use a set of vernier callipers to measure and copy the key.
That way, later on you can genuinely 'make' a key with just a key-code, an impressioning file, and the spec sheet for the spaces \ depths.
It's a brilliant exercise to keep them busy for an hour or two =P
Adding a new key to some cars is pretty simple, but some can take silly routines like: "5 pumps of the brake pedal, two turns of the ignition, then open the drivers door"
We call these a chicken-dance =D
I've always found it easier to get your keys cut somewhere that Clones the keys, that way the car thinks it's exactly the same key, not a new one.
Example: your key might have the magic RFID number 4213, your spare key is numbered 5382. When you add a new key, it might be 4915. the car 'sees' 3 unique keys.
But if you clone your key, it's just another 4213 =)
Dan
On a side note, paper grocery bags (the thick brown ones) can be used to make lead molds for simple blocks or ingots. The flash point is over 600 deg so they won't ignite.
The only difficulty I've ever had was getting the person cutting the key to understand that I'm aware that the key won't start the car and that wanted it for my wallet incase I lock the keys in it. They're generally trying to be helpful by explaining that you can't just cut an RFID key and have it work but once you explain yourself they’ll cut it.
As for damaging the car, that's just not true. RFID keys are passive RFID which signal an electric switch that allows that ignition to start the car if an authorized key is present. Saying a blank key can damage your car is the equivalent of saying that not having a key in you ignition could damage you car.
I had a copy made of my honda key that has a RFID chip at my local ACE hardware that I keep in my wallet in case of locking the real key in like you mentioned and it was only a couple dollars including the blank. Also, if the place that sold you the blank wouldn't cut it for you, which seems odd to me, a locksmith should do it.
Great Big THUMBS DOWN.
He said "Ok, but it will only be good for opening the door."
$1.24
Approximately 45 seconds.
Got a hot dog on the way out.
Here is how it works. 1. owners key is inserted into slot in the reader.
2. reader tells if the key may be copied or if it is a restricted key.
3. if key may be duplicated and the store has the key head in stock, then the key is readay to go.Yes, the after market key is a kit and only a kit! ****Here is the tricky part- some/most auto mfgs require that you use a initiation sequence upon inserting the new key into the ignition. IF THIS STEP IS NOT DONE CORRECTLY YOU WILL LOCK OUT YOUR CARS COMPUTER! and you will then have to go to the dealer to get that issue fixed. Expensive and it will ruin your day.
4. these copies generally run about $75USA on the average to make. Not cheap, but way cheaper than going to the dealer.
5. The only keys that we were not able to copy were the "lasesr cut" keys. they take a laser (duh!).
6. off topic but there are some Master brand padlocks that look like the key should be a standard key blank. This is not true. They take a slightly thicker blank that is not interchangeable.
I searched eBay for a few weeks, bought 3 correct ID fobs, and 3 new metal stems for about 70.- total. The fobs still need to be programmed to work with the specific car, and you need a dealer to go online with Audi to get immobilizer codes.
I went to the service department at lunch time, (use the back doors, and catch the techs on lunch break ) and was able to get a tech to code all 3 fobs for $20.-.
I then had the parts guy cut the 3 new metal portions for $15.00. Total outlay for 3 new "proper" keys? $120.- Total price at Audi parts counter? $810.- plus service department fee plus tax!
My point? Check out alternate solutions before spending money.
