3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RFID Reader Detector and Tilt-Sensitive RFID Tag
The 'rub'
Want to detect the presence of RFID readers? Want to control when a RFID tag is active or readable? We describe how to do both using bits of copper and card, and some readily available electronics hardware.
Longer preamble
Radio frequency identification ( RFID) is rapidly growing in popularity. RFID tags are found everywhere. They're attached to container freight, in those funny-looking white labels you find in newly purchased books, embedded in many corporate ID cards and passports, etc. The tags have a few common properties: they transmit a unique ID number, are optimized to be 'read' from predefined distances, and are usually small so they can remain unobtrusive or hidden.
RFID readers are used to track nearby tags by wirelessly reading a tag's unique ID (see Figure 4); a tag simply has to be brought into physical proximity with a reader to be read. Readers are mostly used for industrial or commercial purposes, e.g. asset tracking or electronic payment. Wal-mart use RFID tags and readers in their supply chain. The technology is also used in mass transit systems in cities like London and Hong Kong. In Japan, many mobile phones incorporate readers to enable e-money payments in shops and vending machines.
For those of us who want to experiment with RFID, the problem is that the technology is almost always black boxed. That is, the inner workings of a tag and its interaction with a reader is hidden from view, and thus difficult to have much control over.
In the two exercises that follow (building a RFID reader detector and a tilt-sensitive RFID tag), we offer an example of how you can start revealing some of the workings of RFID and thus gain some control over the technology. The two exercises also hopefully show that the technology is relatively simple and how it can be extended to support some interesting interactions. We offer some other possibilities that build on our examples at the end.
Step 1Material and Tools
Material and Tools
This section provides an overview of the necessary materials and tools.
Materials (see Figure 1):
We need the following material to built the basic RFID reader detector.
- Cardboard (around 100x70 mm)
- Conductive copper tape (e.g., order number 1218478 at www.farnell.com)
- Capacitor 82 pF (picofarad) (e.g., order number 1138852 at www.farnell.com)
- Low current LED (light-emitting diode) (e.g., order number 1003207at www.farnell.com)
Tools (see Figure 2 and 3):
- Craft knife and scissors
- Insulating tape (e.g., order number 1373979 at www.farnell.com)
- Soldering iron and solder
RFID reader for testing (see Figure 4):
To test our RFID tags we need an RFID reader that can operate at a frequency of 13.56 MHz.
There many readers for this widely used RFID standard, for instance the Sonmicro MIFARE USB reader (http://www.sonmicro.com/).
Note: The Phidget RFID reader does not work with the tags created in this project, as it uses a different frequency for communication with the tags (125 kHz).
Advanced material (see Figure 5):
The following material is necessary to build the second part of the project: the tilt-sensitive RFID tag.
- Micro tilt switches (e.g., www.digikey.com)
- RFID ICs (e.g., MIFARE Standard 1k, part no. 568-2219-1-ND at www.digikey.com)
106 comments
1-40 of 106next »
May 21, 2012. 4:17 AMMaknum says:
Can you make the antenna as big as anyone would want it to be? For example: half a metre? I am making an gramophone-like player for kids. Where they can place cubes that represent different tones on the "installation". But all RFID antenna's that are for sale are to small for the radius.
May 11, 2012. 7:21 PMDoctorDv says:
You should enter this in the kit challenge.
-Doctordv
Apr 28, 2012. 8:12 PMDoctorDv says:
I am new to electronics and RFID, but how does the LED get the power to light up? Thanks for the great post!
Mar 1, 2012. 10:28 PMjnandakumar says:
Please tell me why the tilt switches are required?
Feb 3, 2012. 10:26 PMdhruvil_shah says:
Can you please tell me the dimensions of the antenna you have made along with the spacing between two loops?
Thanks!
Jan 10, 2012. 6:57 AMyaly says:
can i use nickel tape instead of copper?
Dec 19, 2011. 9:23 AMrobertrunyon says:
Would it be possible to use clear nail polish, instead of the insulating tape, to cover the the antenna loop where the antenna lead crosses?
Also, would it b epossible to use a "zig-zag" or "back and forth" pattern instead? This way it would be to possible prevent the crossings in the first place.
Sep 12, 2011. 12:20 AMkgee says:
Nate Marquardt? lol
Nov 29, 2010. 9:26 AMScottSEA says:
You should change "stripes" to "strips"... otherwise, a very nice instructible.
Aug 4, 2011. 2:31 AMElectron229 says:
Who cares.
Jun 11, 2011. 3:28 AMpentagon123 says:
Cool :)
Nov 11, 2008. 1:19 PMcooldog says:
if you add more conductive boxes to the RFID tag reader will i work at farther ranges
Oct 25, 2010. 4:09 PMB.F.L.M says:
To improve the signal quality, wouldnt it be better to use a different metal such as steel or aluminum? Or, in this case, would that be unnessacary?
Apr 21, 2009. 6:15 AMdagenius says:
For the antenna, is there any place other than on the internet where copper tape is readilly available?
Sep 10, 2010. 9:13 PMstatic says:
Alternately you could etch the antenna, and circuity on a PC board using materials readily available from Radio Shack.
Oct 8, 2009. 4:36 AMmkerr says:
 Stained glass supply shops will have copper foil in a number of sizes.
Oct 5, 2010. 5:59 PMbensc says:
Hi,
In the middle of step 4 under sub topic tilt-sensitive tag stated that:
"We add the three tilt switches to the tag as shown in Figure 3. The tilt switches are soldered to the copper tape, and it is important to connect them in a slight angle (around 5-10 degrees) as shown in Figure 4. This makes sure that the silt switches are in a closed state while the RFID tag is in a horizontal position, and in a open state while the tag is in a vertical position."
I not understand about the concept behind, why we need to connect the tilt switch to be slight angle (around 5-10 degrees) and how the orientation of the tag affect the state of tilt switches (open/close).
Can anyone here please explain to me or send me any link to the related page will do. Your help will be appreciate.
Oct 12, 2010. 1:13 AMzimmemic25 says:
because "tilt switches" are opened/closed by tilting them relative to gravity. so if you use 3 tilt switches, orientated differently, you can approximate the orientation of the tag. (see http://en.wikipedia.org/wiki/Mercury_switch for an explanation of these switches)
Sep 30, 2010. 1:15 PMnadav says:
whats the voltage and milliamps going to the led?
Sep 25, 2010. 11:29 AMcherishcherub says:
whoooa, £18 for some conductive copper tape!
they sell them for £1 here what's more,
its available in 5mm so you only have to halve it...
Sep 2, 2010. 11:28 AMMore power! says:
Hey there, nice instructable! I have a few questions about it though...
1. How would one go about making the detector actively powered?
2. Could you make the antenna on a PCB? Or would the copper be to thin?
3. Is there possibly a way to make an Über charged, directional RFIDcard/gun?
Q1 is to try and make it have a further range, Q2 is to see if I can make it in school with minimal materials, Q3 is just to make a replacement for my ID card (needeed to get into buildings)
Any help, from anyone, is much appreciated. Thanks!
Aug 23, 2010. 7:15 PMzack247 says:
this reminds me of go passes. (bus transit passes here in saskatoon) i took a empty one use one and found a similar thing as this inside it. a large antenna, and a small black shiny square at the 2 ends of the antenna
Dec 21, 2008. 12:52 AMOpenyourmind says:
Hello,
first of all, I would like to say that I know absolutely nothing about electronics, and, of course, RFID... So it seemed impossible to me, at first glance, that it would work !
Then I decided to have a try. I went down to my local electronic stuff supplier, bought all the required components and built a sample...
What was my surprise to find out that it actually works !
So I would like to thank you for your GREAT Instructable. Very well explained and documented.
Now, here are some questions...
How are "stored" the informations into the tag and how is it possible to modify (interact with) them ? You say that The technology is also used in mass transit systems in cities like London and Hong Kong. In Japan, many mobile phones incorporate readers to enable e-money payments in shops and vending machines.
Do they need a distinct "writer" and a distinct "reader" ? How come the reader can not also write ?
If a Faraday cage would "shield" the tag from the reader, why shoplifters don't simply coat the tags with some metal (aluminium foil) ?
What if I put two (or several) tags close to each others ? Will the reader get confused ?
Finally, are you some kind of electronic engineer/teacher ?
I am looking forward for more Instructables from you !
Thanks again.
Apr 5, 2010. 11:57 AMmacxiv says:
 Hi Nmarquardt, I have a dumb question: Could a person attach an RFID tag to something like a set of car keys, and use an antenna such as the one you describe here to make them "findable"?
Jan 4, 2010. 11:27 AMolmstw says:
Unfortunately, Aluminum foil works perfectly.... as do some very inexpensive plastic films, which I will not name here...
This one of the Achilles Heels of RFID
Aug 25, 2011. 12:33 PMOpenyourmind says:
Thank you for your reply... Here is the picture of the RFID detector I built. It lies over a mass transit system card. I tried to bring both card at the same time from the reader, and the bip was much louder than usual and the LED fully lit up (normally it flashes) ! I also tried with my cellphone in the same hand, and it acts like a shield so the LED didn't lit. Then, I carefully pay attention to the reader during the rush hour. People were swiping their card all at the same time, but the reader didn't seem to get lost... Can I compare the MIFARE you are talking about to some kind of (computer) ROM ? And BTW, you are right about not getting too much infos about the Faraday process ! I am fascinated by this technology. Thank one more time for your Instructable and your many answers. :-)
Jul 9, 2010. 12:11 PM_soapy_ says:
Ok, as far as I know (I'm sort of in the industry of beating these things sometimes) the "multiple tags" problem is solved by each card replying at a slightly different time.
There is a mechanism for the cards to wait for a time period for a second or further transmission, when the reader polls them. The software in the reader simply ignores multiple hits in a given timeframe.
There is a jammer that you can make, that jams the RFID system by *always* responding to every request, and responding constantly. This defeats the random time waiting that the cards use to get a clear transmission.
(If you are thinking that simply waiting a [pseudo-random] moment before trying again seems a bit inefficient, well, it is, but since even a crowded place would have only a few dozen tags within range (about 10 metres is the maximum, and normally it's 1 metre) and the tags are talking at over 1 million bits per second, each card takes well under a millisecond to do it's thing. So there is plenty of time for anything human scale to work, with perhaps 5 cards a second tops going through a scanner.)
Mar 13, 2010. 6:11 PMbroken_to_fix says:
 i found one of those rfid chips in one of those little wind up toys! HAX LOL
Nov 19, 2008. 7:51 AMk-twizel says:
Just wondering if anyone knows how to program a RFID with a custom ID... thinking about an RFID blocking purse/wallet that has a 'honey pot' tag on the outside with a custom message like "Byte Me" or "Hands up, Sucka!"
Jan 4, 2010. 11:18 AMolmstw says:
All RFID Chips have a unique serial number already stored in them, as well as most have "writeable" memory to allow adding additional info... UID etc...
As to how to "program them, this is usually done with an RFID reader.
Jan 30, 2009. 3:15 PMste5442 says:
Check out Mifare or search for 'mifare' or rfid on the Farnell website - they sell the blank cards as well as readers etc - not as much fun as this instructable though ;-) Very nicely done!
PCB Police Electronics Forum
Jan 14, 2009. 4:35 PMel greeno says:
I have a contactless vending card at work which has a small chip inside. Do you think this would use this sort of technology? More importantly, would i be able to use one of these writers to add credit to my card??? Lol.
Sep 10, 2010. 9:02 PMstatic says:
Keep in mind these are just ID chips, like the mag stripe on the back of a credit or pass card. The system will still communicate with system server. You will get no more credit than the server say you have available.
Jan 26, 2009. 4:24 PMebidk says:
First question: Quite likely. Second question: Maybe. It depends how the system works. In any case, you shouldn't try it. If it works it's stealing or fraud, if it doesn't work they might be able to find out that you tried.
1-40 of 106next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:nmarquardt
