3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
RFID Reader Detector and Tilt-Sensitive RFID Tag
Step 4Tilt-Sensitive RFID Tag
We now describe the process of how to build a tilt-sensitive RFID tag. This extends the previous exercise.
Antenna
The antenna for this second RFID tag is similar to the first antenna we built. We thus need another piece of cardboard and to repeat the steps described earlier in STEP 2 of this instructable.
Tilt-sensitive tag
Next, we add additional copper tape connections to the tag, as shown in Figure 1. These connections allow us to connect three tilt switches, a capacitor, and the LED to the antenna. Again, all the connections of the copper tape are soldered together.
We add the three tilt switches to the tag as shown in Figure 3. The tilt switches are soldered to the copper tape, and it is important to connect them in a slight angle (around 5-10 degrees) as shown in Figure 4. This makes sure that the silt switches are in a closed state while the RFID tag is in a horizontal position, and in a open state while the tag is in a vertical position.
Again, we also add an LED and a capacitor to the antenna as shown in Figure 3 (we use a different form factor of the capacitor here just to illustrate the alternative options).
Testing the tilt-sensitive tag
We can now use our Sonmicro RFID reader again to test our new tilt-sensitive RFID tag. The tag is activate while in a horizontal position as in Figure 5, and is inactive when in a vertical position as in Figure 6.
Using RFID chips
We can now replace the connected capacitor and LED from our tag with an RFID chip (e.g., the MIFARE 1k shown in Figure 7). By doing this, the activity of our tag is no longer visible through the LED, but our tag is then readable by the RFID reader and responds with the unique ID number of the chip.
1 comment
Oct 5, 2010. 5:59 PMbensc says:
Hi,
In the middle of step 4 under sub topic tilt-sensitive tag stated that:
"We add the three tilt switches to the tag as shown in Figure 3. The tilt switches are soldered to the copper tape, and it is important to connect them in a slight angle (around 5-10 degrees) as shown in Figure 4. This makes sure that the silt switches are in a closed state while the RFID tag is in a horizontal position, and in a open state while the tag is in a vertical position."
I not understand about the concept behind, why we need to connect the tilt switch to be slight angle (around 5-10 degrees) and how the orientation of the tag affect the state of tilt switches (open/close).
Can anyone here please explain to me or send me any link to the related page will do. Your help will be appreciate.
Oct 12, 2010. 1:13 AMzimmemic25 says:
because "tilt switches" are opened/closed by tilting them relative to gravity. so if you use 3 tilt switches, orientated differently, you can approximate the orientation of the tag. (see http://en.wikipedia.org/wiki/Mercury_switch for an explanation of these switches)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:nmarquardt
