loading
This is a cat door/flap that can only be opened by the animal that wears the appropriate RFID tag. Arduino controls the process. It features a custom made antenna large enough to function as a gate, which makes it easy for the animal to activate and quite reliable. Some methods and techniques are borrowed from my previous project, the RFID cat feeder. Whereas the feeder controls access to a food bowl, the door controls access to an entire room. The latest code can also distinguish between tags to allow the system to behave differently for different individuals.
How it works:
1. In the beginning the door is locked, cat is outside
2. Cat walks up to the gate, RF tag gets read within about 4 inches
3. Door unlocks and a light comes on.
4. Timer ensures that door stays unlocked long enough to give cat a chance to respond
5. Cat pushes open the flap and enters
6. Flap falls back, activates Hall effect sensor, and the door locks
7. Going from the inside out, an infrared proximity sensor detects the presence of an animal if within about 10 inches and unlocks the door.
Most animals will quickly learn to push the flap in response to the click (lock) and the light. Make sure that the edges of the door and the doorway are padded with soft material for when the tail gets caught! A few painful experiences may be enough to make the cat never want to go in there again.
 The electronics are shown without enclosure, but it is advised to put an enclosure around the electronic parts once you're done. It is not further discussed in this Instructable however.
Step 1: Parts List
- Arduino Duemilanove
- 5V RF reader module (Seeed Studio 125Khz UART or equivalent. Most readers come with a small antenna. To use the custom made antenna discussed here, you need a reader that allows connecting an external antenna)
- RF tag (I used these 35mm disc shaped ones)
- About 86 feet of 24 gauge magnet wire (longer than the piece shown in the photograph)
- Sharp GP2D12 infrared proximity sensor
- Two 12V electronic cabinet locks (Nordson electronic). Solenoids, basically.
- One 12V DC power supply
- Two TIP120 Darlington transistors
- One Hall-effect sensor
- One or more magnets to activate Hall-effect sensor over a range of about 2cm
- One 100 Ohm resistor
- Four 2 KOhm resistors
- Two pushbuttons
- One LED
- One hinge (one that moves easily but without much lateral movement, for precision)
- One 6" x 9" piece of 1/8" thick Plexiglas and perhaps another piece of about 6" x 3"  to mount the locks
- Hookup wire, including about 27" extra thin (26 AWG or thinner)
- Nuts, bolts and serrated washers
- Rubber isolation strip or other soft material for padding the edges of the door and door post
The system comprises several 'modules' (solenoids, RF reader, and so on). One of the pictures here shows the basic plan with the modules connected to the Arduino (the electronics). In the next steps the mechanical parts and each of the modules will be discussed in detail.
Step 2: Make the Door
The door is a Plexiglas flap hanging on a hinge. At the bottom, the doorpost will have two solenoids, one on each side of the flap, to block unauthorized animals from getting in. Pretty straightforward. Just a few things to keep in mind:
Make sure that in the resting state, the flap is centered in between the two solenoids. In the picture that is in the red area around the dotted line down the middle. To achieve this it helps to have no heavy things hanging on one side, and to use a hinge with little friction.
It helps to have a hinge without much lateral movement (sideways movement within the plane of the wall). This will help to make the hall-effect sensor (a magnet-actuated switch) work. I will discuss this more in detail in step ...
The door needs to be rigid but light-weight so that it is easy to push it open and doesn't hurt when a tail gets caught. Make the corners smooth and add padding on the edges and the door post to minimize tail tribulations.
Step 3: Make an Antenna
The antenna is nothing more than a coil of magnet wire connected to the RF reader. Most RF readers come with an antenna, but some allow the use of an external antenna. For this project I made a square antenna of 10 x 10 inches by winding 24 gauge magnet wire 24 turns around a sawed off bucket to make it sturdy. The distance between turns has to be as small as possible. I mounted the thing on the plywood with two pieces of wood as spacers to make it stand off from the wall a bit so the cat could activate it farther from the wall. The 35mm disc tags that I use are read up to 4 inches of the plane of the coil. The RF reader and antenna are powered with the 5v from the Arduino. Even though the Arduino works fine with just the USB cable, the RF reader works better when the Arduino is plugged into the wall with the 9v power adapter
More info about coil antennas:
Microchip Inc. Antenna circuit design for RFID applications (pdf)
Step 4: Hook-up the RF Reader
This project consists of several 'modules' that you need to hook up to the Arduino and test in advance. First hook-up the RF reader. You can use the 5v output of the Arduino to power it, and a digital port (I used 2) to get the signal. The RDM630 that I used also has pins for a led that I don't use. It also has an RX pin to send info back to the RF reader, but I don't use that either. Hook-up your antenna, get a tag and use the serial monitor of the Arduino to see if it's detected. Now you can also start working on improving the antenna by trying adding or removing turns, trying different shapes et cetera. Power the Adruino with the 9v power supply, not just USB because at least in my case that didn't work. You can download the file named 'rfid3.pde' to test. The code requires NewSoftSerial.h which can be obtained here
Step 5: Add Solenoids
Hook-up the solenoids up to the Arduino as in the schematic: connect the TIP120s to digital ports 5 and 6 with 2k resistors in between. One pin goes to ground, the other goes to the solenoid, with a diode across it (make sure you get the polarity right), and to the 12v supply in the end. The other wire of the power supply is ground. Connect that to the other grounds. Just connect all grounds of all components including the Arduino together. Over here you can download code to specifically test the two solenoids.
Step 6: Add Hall Effect Sensor
The Hall effect sensor is for detecting whether the door is in the center, i.e. within the range that closing the locks makes sense. There are other solutions possible, such as mechanical/optical rotary encoders, contact sensors, beam break sensors. The main reasons for choosing a Hall effect sensor were that it does not add friction, it can be covered entirely, and I also was just curious how they work.
I did not want to put magnets on the door because that would make it heavier, so instead I put the switch on the door and the magnets in the door post. I had to use thin, very flexible wire otherwise the rigidity of it would push the flap off center. The sensor and wire is simply taped to the Plexiglas. I have two little magnets in the door post. At the closest point the sensor and magnets are 5mm apart. The range is about 3cm.
Connect the signal pin of the Hall sensor to pin 4 and to through a 100 ohm resistor to 5v. Connect ground pin to the other grounds and the vcc pin to 5v. Add an LED to digital pin 7 with the appropriate resistor (used a green one with a 220 ohm resistor).
Download Hall_effect.pde to test this part of the system.
Step 7: Add Proximity Sensor
For this system I only cared about which cat enters, and any creature may exit. Thus, I only needed RFID on one side. The door should open to any animal that approaches from the other side. An IR proximity sensor works well.
Connect the out-pin of a Sharp GP2D12 to Analog port 0, the ground pin to the other grounds and the vcc pin to 5v.
Download IR_test_analog.pde to test this part of the system
Step 8: Add Two Buttons and Load Final Code
Finally you can add buttons to open the locks manually (see schematic). .
In the final code downloadable here, I stored the value of two tags worn by the our animals, one with and one without access. When the animal without access tries to get in, the door is locked immediately.
byte goodcode[6] = {0x1C, 0, 0xFC, 0xB2, 0x90};
byte badcode[6] = {0x16, 0, 0x78, 0xE7, 0xFE};
You have to find the code of the tags you are using and put those values into the arrays 'goodcode' and 'badcode'. The values are hexadecimal which need '0x' in front of it in this programming language.
If you don't want to tag the other cat, shortening the open time (smaller value for variable 'open_time') can help, although that puts the burden on the cat with access to respond faster.
It is a good idea to put an enclosure around the electronics, but that will not be discussed in this instructable.
On a final note, if your antenna has a large range extending into the secured area, you may need to calibrate the positioning of the antenna and the proximity sensor a bit to make sure the RFreader is not activated from the inside. If the cat is inside and wants to go out, the proximity sensor has to detect the cat first. Once that happens, it is okay because in that part of the program, the RF reader is not checked.
<p>Hello, you said that the code requires newsoftserial code, how can i get it to work?</p><p>Thanks!!</p>
<p>Did you get this to work??</p>
<p>how do you know if you've got the windings right? Meaning, why 24, and not 30?</p>
<p>Do you have to use the Arduino Duemilanove or can you use others such as Arduino Uno?</p><p>But great project!!</p>
<p>did you get any response on this matter? I am looking at this project but can only get hold of Uno</p>
<p>Great project. I case anyone hasn't seen this, a manufacturer has made a commercial version, &quot;SureFlap Microchip Cat Door.&quot; On Amazon at <a href="https://www.amazon.com/gp/product/B003EGIM3O/ref=pd_bxgy_199_3?ie=UTF8&psc=1&refRID=QD08RFMJYA9VEEQ0MNYX" rel="nofollow">SureFlap Microchip Cat Door- White</a> </p><p>They solved the issue of getting the antenna nearer the implant location by extending it out from the flap and extending the flap the other way to create a 3-4&quot; tunnel, with the loop at the extreme outside end I assume. They also offer a RFID collar tag, in case your pet's tag won't read or doesn't have one.</p><p>Maybe someone can satisfy my curiosity about the Amazon image: How did they install it in a double pane thermal patio door? I assume once they broke the seal the window would get condensation inside.</p>
<p>So does this thing work? I see many comments stating the antenna does not work. I would like to make this but I don't want to waste my time if it doesn't work. Please let me know if the antenna issue has been resolved.</p>
<p>Same problem as everyone else, although the largest antenna I have tried so far is only 3&quot; x 4&quot;. Always the same result with all of my antennas so far: approximately 1&quot; read distance using a keyfob. They all work, but I am not seeing ANY increase in read distance as the antennas get bigger. I have tried several different brands of 125KHz readers. I have also tried two different brands of 13.56 MHz readers but the read distance only improves to 1.5 inches. Completely stumped.</p>
<p>It cannot be uploaded onto the arduino...all directories are correct and still can't identify NewSoftSerial.h please help...</p>
<p>Did you install it as a library? See here for details if not:</p><p>https://www.arduino.cc/en/Guide/Libraries#toc4</p>
<p>Hi Landmanr, I'm attempting to put together a RFID setup to keep my dog away from the trash can. I'm attempting to build a larger antenna. I've used the datasheet you provided as well as a multilayer air coil antenna calculator found online to attempt to produce a 8.5 in antenna and the best I could do is have the tags read when touching the coil much like one of the comments below. </p><p>I attempted to replicate your antenna to the T and cannot get it to work. I'm leaning towards inductance as the factor that is wrong with my antenna since I must plug this into the equation in order to get the proper amount of turns per layer. The data sheet for the RFID reader does not list required inductance for the coil so I tried to reverse engineer your antenna using a inductance calculator and it seems that your antenna is somewhere around 300 UH. Could you verify this for me? Thanks!</p>
<p>Hi! I'm trying to build the cat flap. I have almost everything finished, except for one step: I tried to make an equivalent antenna, as described, by wrapping 30 gauge magnetic wire around a 26x17 cm PVC box (I need 26.5 loops). I even bought an LC meter, to make sure the inductance is the same. The antenna that came with the RFID module is 477uH, and the one I made around 472uH (It seems somewhat dependent on where and how exactly the exit wires go), but I get nice strings from the original antenna, and nothing from the one I made. I checked the resistance, and it is almost the same - 6 ohm (original) vs 8 ohm (mine). </p><p>What could the problem be??? I can't figure it out. </p>
<p>I built another antenna, this time using 21AWG. Same result. However, now I noticed that when I bring the tag very close to the loops - pretty much rubbing the wires, then it is read with both antennas. Now I need to convince the cat to rub her tag on the wire... maybe catnip spray?</p>
<p>Did you ever figure it out? I'm having the same issue where I need a larger antenna, except that I'm not getting anything at all with mine.</p>
<p>No, I didn't. My next step was to try other RFID readers, but I haven't done that yet.</p>
<p>I'm trying to build this project except that I already have an electronic dog door mechanism. The door I have uses an ultrasonic collar to trigger the door and it's super finicky, the dog collar is large for a small dog, and the batteries are proprietary and ultra expensive. So my goal is to hack the door I already have to use RFID instead of ultrasonic.<br><br>The exiting through the door part is easy. I'm using a micro PIR sensor for that and it works great. The coming back in will need the RFID and the reader and antenna I have is very short range. I belive it's the same one used in this project. I have to place the tag right on the antenna. Although to be fair I have been powering it over USB. I tried to build my own antenna using the same sized wire and method shown here (10x10 inch square at 24 winds) but with that one it doesn't read anything at all. I also don't have equiment to measure inductance (that I know of).<br><br>I've looked at the microchip pdf but it's over my head. I wish I could just buy a large antenna that I could use that would read the dog tag at the distance I need.</p>
Hi,<br>Do you think it could work with another rfid protocol for example Mifare tags running at 13.56MHZ? The reader could be a PN532 board, which is cheap, my only concern is which would be the reader's range ? Also get a $3 arduino pro or mini can reduce the global cost :)
<p>Range on the PN532 is a few inches, almost touching basically. </p><p>It's range is already maximized. Modifying the antenna changes the inductance of it. Even if you wanted to supply more power to it, the board doesn't support it. </p><p>13.56 MHz is meant for close range. </p><p>I would probably stick to using a EM4100</p><p>I guess you could also use a active tag(powered) but I don't think the cat would appreciate a project enclosure on it's collar..</p>
<p>Some people have suggested putting the antenna in a tunnel in front of the door. I am thinking of using this design to make a trap for cats which have not been tagged, so that is an attractive option for me. If I do that, is it likely to be sensitive enough to detect implanted microchips?</p>
<p>First and foremost, this cat flap is huge. For a cat you can get away with a square hole 20 cm on a side (though I'll admit that I prefer 25). Second, if getting tails caught is a problem for you I recommend that you make a gap between the door and the wall about 1.5 or 2 cm wide that can pass a tail, but not a limb (there will of course not be a gap on the lock). Then go get some rubber and put and nice gasket around the flap to keep in the heat.</p>
<p>Typo:</p><p>I said &quot;a tail, but not a limb&quot; when I meant to say &quot;a tail, but not an animal.&quot;</p>
<p>Dear creator!</p><p>My name is Miras, and I plan to implement the same schem using arduino+ rdm6300. Could you contact with me by email miras.dolayev@gmail.com. I've got some questions about antenna calculation.</p><p>Will wait for you friend!</p>
<p>Good instructable, nice job. Most US pet pittag are usually 125 and EU 134.2 although there are some newer ones out there with oddball frequencies these days. On a good day with one of the handheld scanners the vets use I've managed to pull a number off an animal at about 6cm but most days its 2-3cm through skin if I can find it at all. Try moving you coil into a hood over the top of the flap rather than round the flap or even double up on your coils with them 90deg to the flap so that your cat walks into the field first</p>
<p>this is soo cool..!</p>
Awesome! - Anyone know how to read the standard implanted pet RFID tags? It would be even better to do this and not need an external RFID tag if your cat was already chipped with an internal implanted RFID tag.
Implanted pet tags are usually tuned to 134.2 KHz or 125 KHz (Wikipedia), so it is the right frequency. The implanted tags are really small though, which could make the read range very small.
I have tried a 'Home Again Pet-Tracking Microchip' but I could not get it to work.
:-(<br> <br> For those sharing the frustration about the implanted tags:<br> <br> Knowing the very real reading distance problem (seeing vets pressing their handheld devices to the skin), a good explanation for the failure of the door setup is still lacking. Can anyone (unfortunately only an electromagnetic fields expert...) tell what factors negate these important things below, making a reading still impossible?<br> <br> A door<br> <br> a) has a waaay bigger (stronger) antenna than a handheld reader, and<br> <br> b) <em>(this feels even more important)</em> the cat PASSES THROUGH the antenna, <em>theoretically</em> decreasing the tag distance (and so the required reading distance) to ZERO! :-o<br> <br> So, considering these important benefits, what is the real reason for being unable to read those tiny tags? (The physical model behind the equations is invalid at zero-distance? Or certain effects, losses <em>inside</em> the antenna are just ignored at the usual non-zero-distance cases? Or tag position offset from the antenna axis weakens coupling that much?)<br> <br> Just curious (= still not given up hope... :) ).<br> <br> Thanks a lot!
Wait, wait! :) Just realized, that in this setup, the cat actually <em>cannot pass through the antenna</em> to open the door, because the closed door stops it too far from &quot;Plane Zero&quot;...<br> <br> A tunnel-shaped configuration would be required to test the zero-distance case.<br>
There are several issues with the implanted chips. Frequency can be one, although from my reading it appears to be an overrated issue, in that the 134.2 kHz and 125 kHz chips can often be read by the same reader. Another issue is the number of digits being read. I know that one type of pet chip uses 15 digit tags, while many of the readers available to hobbyists only read 10 or 12 digits. A third issue is that some brands of pet chips use encryption.
Those implanted chips are really tiny. When the vet reads the chip with a purpose made handheld reader, it has to virtually be pressed up against the cat's skin/fur. The signal created when excited by the reader just wouldn't be strong enough to be useful.
(below) In case anyone else has this issue, Arduino 1.0 and later doesn't need 'Newsoftserial' added to the library. Instead, insert the code given into Arduino and change 'Newsoftserial' to 'Softwareserial' in the code itself. It is placed in the code twice.
What needs to change on the RFID code? Arduino doesn't seem to like it.. :(
good <br>
First, congratulations for your project. <br>Secondly, the questions: <br>1. You said in material that used 4 x 2kohms resistor, I just saw 2 in the schematic, where are the other 2? <br>2. I didn't understand why the diode in the solenoid part, can you clarify to me? <br>3. If I use a 6V solenoid, do I have to use a different resistor? <br>Again great job and when my material arrive from china to brazil I will try to make a bigger wall dog door, if I succeed, maybe I post here my modifications with the right citations to your project. <br>Thanks in advance
Antenna resonance details are pretty important, more so than, say, the thickness of the wire used for the coil. Please see https://www.instructables.com/id/RFID-Reader-Detector-Easy-to-Build (RFID in Instructables) and you will notice a RFID detector here with an LED that uses both a coil AND a capacitor that matches 125 kHz. The LED on this detector lights at the farthest distance from the RFID reader when the coil and capacitor resonate at the frequency of 125 kHz. Roughly speaking, my handwound coil of about 300 uH with about .005 uF of capacitors in parallel with the coil resulted in the best lighting of the LED at a distance of about 4+ inches and mostly meets the requirements of the formula; freq = 1000 divided by (2 times pi times the square root of L times C) where freq in in kHz, C is in uF and L is in uH. I believe that using a capacitor in parallel with the antenna coil is pretty common practice. The wound coil is &quot;fine tuned&quot; by capacitors hooked up in parallel with the coil...
Thanks for this, I've been using this instructable to build a similar rfid dog door. One of my final steps is building a bigger antenna, but I can't get it to read anything. Is there a specific number of turns or size of antenna that has to be built?
Yes there are a number of factors that all together determine how well the antenna works. Your antenna is tailored to the frequency you want to use and the number of turns depends mainly on the antenna diameter (more turns required as the diameter gets smaller) and on the thickness of the wire. You can find detailed information here: http://ww1.microchip.com/downloads/en/AppNotes/00710c.pdf<br>10x10 inches was the biggest I could get with this RF reader. I varied the number of turns as a way to 'tune' it, trying it out with a tag each time. <br><br>
Please see https://www.instructables.com/id/RFID-Reader-Detector-Easy-to-Build and you will notice a RFID detector here with an LED that uses both a coil AND a capacitor that matches 125 kHz. The LED on this detector lights at the farthest distance from the RFID reader when the coil and capacitor resonate at the frequency of 125 kHz. Roughly speaking, my handwound coil of about 300 uH with about .005 uF of capacitors in parallel with the coil resulted in the best lighting of the LED at a distance of about 4+ inches and mostly meets the requirements of the formula; freq = 1000 divided by (2 times pi times the square root of L times C) where freq in in kHz, C is in uF and L is in uH. I believe that using a capacitor in parallel with the antenna coil is pretty common practice. The wound coil is &quot;fine tuned&quot; by capacitors hooked up in parallel with the coil...
Thanks, I also found more details from your pet feeder project. I've made a working antenna now but it's range is still pitiful. One more question, does it have to be a perfect spiral or can the wire overlap itself?
On my antenna there is overlap, it's not a perfect spiral.
Though possible in principle, it would not work with the thing described here (I have tried it). Even if you had the proper reader, the range would likely be in the order of centimeters, so the animal would have to be trained to go to exactly one place to activate it, which might be difficult. I have used a handheld reader and I had to hold it pretty much against the animal right above the chip.
Great 'ible! Is there any way you could use the pet id chip (that both of my cats already have under their skin) instead of using tags? <br>Many thanks, Duncan
Any chance this could work with the pet ID microchip implant already on an animal?
Great project!!! I am myself on the horse feeder system with RFID. I have one question though. Can U tell what is the diameter [in mm] of the antenna wire ? <br>I tryied to figure it out from the tables and found that 24 gauge is 5,4 mm wich is not exactly what I can see on UR pictures (or mayby I am wrong ;-).
It's AWG so the diameter is 0.511 mm http://en.wikipedia.org/wiki/American_wire_gauge
Thanks...
Now I kind of wish I had an outdoors cat to try this out with...
I am in the process of building your cat feeder project. I've been to you a couple of times for questions in that regard (thanks!). <br> <br>This project is next. At one time a possum was coming in thru my cat door on a nightly basis. I had to trap him and transport him in my car to a far-off field. I need one of these to keep away these unwanted guests.
Could this be changed somehow to prevent the door from opening if a particular pet is nearby? I have a very small dog that I do want to be able to go in and out on her own, but I also have a cat that I absolutely do NOT want to be able to go outside. I am one of those firm believers that all cats should be indoor cats (for their safety) unless you have a cat-proof yard. I have been wanting a pet door that will let the dog go in and out but locks securely if the cat goes near the door. Also, could this be altered for a sliding screen door as opposed to a solid door? This is something I'd be willing to pay for.
About This Instructable
184,882views
386favorites
License:
More by landmanr:Cast an 'entangled rings' ice sculpture RFID cat door RFID pet feeder
Add instructable to:
