Color-changing RGB Christmas Tree Lights
Here is a quick and easy way to make a strand of RGB LEDs for a Christmas tree.
Step 1Buy some color changing RGB LEDs
My friend Jimmie turned me on to some excellent color-changing LEDs. There are several kinds of RGB LEDs: the ones with four wires are meant to have their colors mixed by a circuit. The ones with two wires change on their own and can't be programmed. But they are fun and perfect for a project like this. I prefer the ones that change slowly, and Jimmie showed me that you can find these on eBay by searching for rgb slow color change on eBay. They will take a week or more to arrive, which is cutting it close for this Christmas.
11 comments
Sep 18, 2009. 2:49 AMaaron2william says:
This Color-changing christmas tree is fantastic.Christmas is the festival of lights, joys and sweets. Animated outdoor christmas decrotaion looking flashy and eye catching. Baically the lights plays game on the picture and these lights says you that today is christmas.
Dec 9, 2008. 12:26 PMjongscx says:
Do they randomly change color, or will they all change at the same time?
Dec 5, 2008. 2:17 PMEdward Nardella says:
I would hope there are resistors inside, because the diodes need a current limited circuit. I am wondering if these could be controlled in a fashion via PWM to control the speed of the color change. I would have used the free resistors they include with a 12v Laptop adapter I have laying around. Thankyou very much for posting this project, it is quite cool. Also when you cut the power I wonder if when turned on they start at the same color or reset.
Dec 5, 2008. 4:32 PMEdward Nardella says:
Actually the fact that they reset may give more control, I bet the circuit has to be off for a certain amount of time (IE 10-20ms) before it will reset. So if you do not turn it off for more than that cutoff you may be able to do some neat things.
Dec 5, 2008. 3:47 PMinventorjack says:
That's crazy! I was thinking about something like this earlier today at work. Then I come home, go on make, and see the link here to your instructable. Awesome! Thanks for sharing.
Dec 5, 2008. 2:57 PMrichms says:
I would twist the wires before soldering since I can see that it would be a huge tangling hazard with them separate. I used some of those leds a while ago for another project and had quite a high failure rate where one of the colours would not work, hopefully china have improved their QC in the couple of years since then.
Dec 5, 2008. 9:38 AMEdward Nardella says:
The circuit does not need resistors for each LED?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:bjepson
I'm an editor for Make and a geek for AS220. I like to hack code and things.
